-   -   I need some help for sway bars...... (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/399008-i-need-some-help-sway-bars.html)
935TURBO 03-18-2008 01:22 PM
Hi Turbomen,
I just got this and have no schematics support for the fitting......rears are OK...but I think I will have some mods to do for the front...isn't it...?......;)
http://img296.imageshack.us/img296/8...317002mrw7.jpg
http://img296.imageshack.us/img296/5...318011mib5.jpg
http://img134.imageshack.us/img134/9...318016mlm0.jpg
cl8ton 03-18-2008 01:29 PM
Serge, I have those exact TRG sway bars on my 930.
Here is a LF corner showing orientation, if you need more pics let me know.
http://forums.pelicanparts.com/uploa...1205872161.jpg
935TURBO 03-18-2008 02:13 PM
Thanks very much Cl8ton...yes that's exactly that one....but that mean I'll have to make 2 holes in the front body for the bar....of course, I'm very interested in getting pics...I'll send you MP with my mail...Thanks....SmileWavy
rsrfan 03-18-2008 03:37 PM
Serge,
there are many excellent threads in the tech forum detailing the installation of through the body sways and where exactly to drill the holes. Additionally, since you like to weld, you may want to reinforce the holes at that time.
JP
rsrfan 03-18-2008 03:43 PM
http://forums.pelicanparts.com/showthread.php?t=384821&highlight=through+body+swa y+holes
http://forums.pelicanparts.com/showthread.php?t=258426&highlight=through+body+swa y+holes
935TURBO 03-18-2008 04:52 PM
Thanks JP....very intereting....and of course, very important...the reinforcement....absolute priority.......:eek:
930gt-40r 03-18-2008 07:33 PM
I am soooo happy that 935TURBO posted this because I have the same issue with my 930
Craig 930 RS 03-18-2008 07:58 PM
Reinforced rear mounts are a must or don't do this sway setup -
I recommend WEVO console sway rear mounts.
fredmeister 03-19-2008 08:36 AM
WEVO rear mounts are a must as well.
Once you go larger rear sway bar the stock mounts will break.....and leave you with broken rear sways at your next track day!
Call TRG where you got the sway bars and tell them to send you the installation instructions for the front units.
935TURBO 03-24-2008 01:54 PM
Problem.....with the rear......Am I doing a mistake.....?
The bar is too close to that plate/support......is it normal...?.....if so, no problem, I'll make a little bracket.......did someone have the same problem...?
http://img395.imageshack.us/img395/4...24a003mxp7.jpg
http://img403.imageshack.us/img403/2...24a005mra1.jpg
http://img125.imageshack.us/img125/2...24b002mth1.jpg
GJF 03-24-2008 03:05 PM
You can do 1 or 2 things.
1) You can add shims under the mounting blocks. Possibly 10mm - 13mm
2) Clearence the transaxle front mount
And as Craig and Fred stated, reinforced rear swaybar mounts ARE a MUSTwith performance swaybars. The WEVO mountes are very nice pieces and make the task easy instead of making custom reinforced brackets.
935TURBO 03-24-2008 03:26 PM
Thanks for the info GJF....I saw what Craig and Fred said...but didn't understand completely why.....so, is that what they/you mean.....
http://www.wevo.com/Products/ChassisProducts/WevoChassisProducts-RARBConsoles.htm
If so, it has to be machined and need some Nylon or Teflon rings.....?
935TURBO 03-24-2008 03:41 PM
Does someone made this upgrade with the WEVO mounts...?....pics...?......
Thanks.
GJF 03-24-2008 03:43 PM
no... you cut off your existing rear swaybar mounts and weld the WEVO units in ther place. They provide a new mount for your swaybar. You will simply bolt the new swaybar to these after they are welded in place.
GJF 03-24-2008 03:52 PM
http://forums.pelicanparts.com/uploa...1206399160.jpg
zeb930 03-24-2008 04:02 PM
Welded the wevo mount about 20mm more rearward/up than the original mount, to clear the gearbox plate.
http://forums.pelicanparts.com/uploa...1206399484.jpg
935TURBO 03-24-2008 04:06 PM
Thanks a lot guys.....so I have to ask for a quotation with the shipping to FRANCE....and how long for the delivery...?....:confused:
fredmeister 03-24-2008 05:42 PM
I needed to make shims to clear the tranny mount bracket as well. The stock rear sway bar came with a bend in the middle of it for this very reason.
Be careful on the passenger side because welding around the fuel pump there could be dangerous. The second turbo fuel pump is mounted up in this area of the car.
hobieboy 03-25-2008 06:27 AM
I believe the TRG bars came with a shim because later cars need them to. I fabricated one for mine as well.
On the Wevo mount, one question/comment - buddy of mine had upgraded his sway bar mount. The mount held up (its now Wevo), but the weak part after this "upgrade" was the sheet metal! The mount and bar actually started tearing the sheet metal off the car so he had to weld & reinforce the whole area. Anyone had experienced this?
NathanUK 03-25-2008 02:04 PM
The advantage of the Wevo is not just that the part itself is strong but due to its size it spreads the load further on the bodywork.
