Thought on this AFR graph?
Alright boys!
I took the 930 to a friends place (not a Porsche tech) to make sure that I was not going to grenade the motor on the CA fuel, and this is what we have: Timing 26* BTDC at 4000 RPM http://forums.pelicanparts.com/uploa...1206856730.jpg http://forums.pelicanparts.com/uploa...1206856750.jpg http://forums.pelicanparts.com/uploa...1206856761.jpg What do you AFR tuning genius's make of all this? The car feels like it is choking from 2-4k RPM, (shuddering and unhappy). The turbo starts spooling at about 2800-3000, but nothing really happens until roughly 4200 RPM. Is this due to The AFR being in the 10-11:1 range? How do I get it closer to 12:1 while bringing the AFR's above 5000 RPM down to the approximately the same range? I do have the Andial enrichment system installed (don't flame me Craig! The thing came with the car!! ;)), but the PO did not have the instructions and was no help in letting me know how system worked. It is currently on the counter-clockwise most setting, with five possible other indexed settings. With my current configuration, am I a good candidate for the adjustable WUR? Or is it over kill for my motor? Realistically I will only be at the track 3-4 times a year, and other than that the duration of time on boost will be, unfortunately, limited... Basically: HELP!!! I'm Lost! -Sean |
Not sure about the andial enrichment set up so cant comment although it looks like you are getting a mass of fuel in there far to early in my opinion,with an adjustable wur and with some tweeking you could iron that out one hell of a lot better and wouldnt need the andial.
if you were still getting too much fuel too early you could also delay the fuel enrichment more with the rpm solenoid! |
***** can the Andial ;-) Look how rich it is on the bottom end and lack of fuel up top.......
Adjustable WUR --- and the RPM switch is definitely needed here (will delay that full boost enrichment until 4500 or so and gain HP and use less fuel, etc etc) |
Am I reading correctly that this engine sees 1.35bar @4000rpm with a 12.9:1 AFR?
What is your engine setup? Obviously this is a problem. That huge black cloud behind you at 2500rpm is killing power, mileage, and washing your cyliders. So yes, you need to make your WUR adjustable and fix all of the parameters - cruise, threshold, and boost. |
- and manage that massive full boost enrichment that can't be tuned out via the adj WUR - an RPM switch is a must in your case.
Not necessarily. It takes more tuning time but full adjustment is possible without the rpm switch.
Could be possible, but from others' experiences it may not be likely.
On a 930 with CIS - absolute full, massive 100% fuel dump occurs at full boost and the way to manage this is with the ~delay~ of full boost enrichment via the RPM switch. Several people over on Rennlist have found this to be absolutely true. This is especially the case if he finds out if he requires additional fuel via the IA fuel head. (Which he probably will not need) A modern turbocharger produces full boost at a much lower point than the 1970s era turbochargers did and all that extra fuel is tough to manage with the WUR alone - and this is why Brain Leask has the RPM switch and solenoid. It sure works well! |
A few of those readings remind me of my blood pressure when I rev my baby up and then my wife comes out into the garage and yells at me to shut that *****ing thing off... have a nice day boyz!!!
My guess is that the rpm switch was incorporated as a shortcut to the detailed tuning required to get it right. Most folks don't have the patients for it. You still have the same amount of tuning if you want the entire range perfect.
Shortcut. Uh...no.
Hang tight, I'll post some information. |
Your course of action should be this:
1) Adjustable WUR from Brian Leask. Tell him what you have and he will send it roughly pre-adjusted. 2) Check AFRs. 3) Adjust WUR. It does indeed take patience, but the instructions are phenomenally superb so it is actually ......fun ;) 4) Check AFRs again. Possibly invest in an AFR (Innovate brand is good) setup. You have so much fuel right before probably full boost (when is full boost on your car?) that this HAS to be adjusted using the WUR. Post full boost (prob 3k and above) to probably 4,400 (very typical RPM switch activation point, by the way) I would surmise that this would benefit from the RPM switch *BUT check and perform steps 1-3 first*. See below for operation and theory: http://forums.pelicanparts.com/uploa...1206924031.jpg http://forums.pelicanparts.com/uploa...1206924046.jpg |
Yes, it is a shortcut. A bandaid if you will.
By adding the RPM switch you alleviate (note I did not say eliminate) the need to go inside the WUR and mechanically adjust the threshold. As I said before, most folks don't want to do that, and that's fine. For product dispersion to the masses that is a GREAT idea which allows adequate external adjustments. BL has a great product and I send folks his way almost daily. Now back to the topic at hand. What is the boost level? Is it really 1.35bar? How was this engine built? |
Craig: :D you know I love you Andial hatred!!! :D
Thank you for the reading! I am very much considering the BL WUR. RarlyL8: Yeah, no **** on the boost levels... :eek: As far as the engine build goes; 3.4L Mahle P&C 7.0-7.5:1 CR (the shop could not remember which compression ratio) SC cams Stock bottom end K27 7200 Turbo Kokeln IC Stock waste-gate (1bar spring) It is throwing me for a loop, my best guess is that I am experiencing higher boost levels than the WG spring is set for because of the GHL headers? Much like the Tail WG's are experiencing with the same headers??? 356-930, and I have also been corresponding and he brought up a good point and question: shouldn't the boost peak just above the WG spring pressure, and then hold steady at that WG's spring rate, instead of tapering off, as shown in my boost chart? I really appreciate the time fellows! -Sean |
Both a K27 7200, or a K27 7006's boost will taper off as revs go up just like your graph shows. They just run out of breath.
If you install a K27 HFS then it will hold max boost all the way to redline, even in 3rd gear... and you should be a little richer up top, like around 12:1 or even 11.5:1 if you go that route. Or it may detonate and break rings, burn pistons, and all that fun stuff. I would recomend Brian's RPM switch and solenoid and adjustable WUR too... The 930 WUR gives enrichment when it sees boost no matter what rpms the engine is turning, so you delay the boost pressure from getting to it until around 4500 rpm with the rpm switch and air solenoid. |
After checking your W/G have you relocated the W/G pressure tap from it's stock location? Assuming the W/G is functioning properly, when I see a boost curve like yours it has been modified by electrics (modern) or relocation (old school) of the pressure tap controlling the W/G. Next, but of lesser importance, your comment about the GHL headers may be contributing to the boost curve shape as their 90 degree branch off pipe from the base of the turbine inlet is widely known to be less than ideal for proper exhaust flow to a W/G. Basically, you are dealing with turbulant flow because of this improper design and stange things happen in turbulant flows. Once you have control of the manifold pressure a slight boost overshoot is generally considered desirable for "response"....but not at 1.35bar. |
Header design does affect waste gate action.
You can get a boost controller or swap in a 0.8bar unit and see where it ends up. The K27-7200 does peter out on top but given your boost and AFR issues that is not a bad thing. I also suggest an adjustable WUR. BL has a good product and can help you set it up. |
Header configuration delivers power to the compressor through driving the turbine. Better configurations deliver more power sooner, but this power should be controlled by the W/G alone, especially at less than maximum flow conditions. Power often drops based on the turbo's size and efficiency but the boost level should remain as set. Being a less than perfect world the boost curve will have a different signature with component changes. As I said, if the GHL headers have a signature of a slight onset boost bump this is desirable assuming it's within reason. Yes, he needs to work with A/F control, and probably needs the WUR upgrades based on the collective experience on this site but I think we will agree he doesn't want it fixed at 1.35 Bar boost. Is it typical to use a .8bar spring to control boost at 1bar? |
The 0.8 bar spring is a bandaid to get around the header design flaw. If 1.0 bar boosts 1.35 bar then 0.8 bar might be good for 1.08 bar given the 35% overboost is linear. Not an ideal situation but it should save the engine if modding the headers is not an option.
Leaving out the RPM switch when required is a questionable idea and makes tuning the thing so much harder.
But if you like that stuff... Brian, you ought tell us exactly HOW this is done with extreme richness at the low end. After all, this is virtually central to 77's problem. ~ That engine is extremely / unecessarily 'peaky'. THe HP curve ought to be much flatter - |
Wow 1.35 bar! OK I am fairly new to the 930. but it seems to me that you definately need to get that boost down. When I installed my GSF headers I was around where you were with a 1 bar spring. I found that I needed to go down to .7 to get my desired .9 bar. As stated above it is probably a real good thing that the turbo is running out of breath. Once you get the fueling sorted out and possibly a more efficient turbo. that motor is going to be hurting at 1.35bar and have much bigger problems. yikes! Just my .02
Eric 87 930 |
I am dealing with similar issues. I am running so rich I cant get an afr under boost above 11 all the way until the turbo pooches out. I am about to yank the wur and send it to BL I am going to try to tune it without the RPM solenoid if possible. then go from there.
EricBritton |
I am planning some changes to my engine soon that will require going into the WUR. I'll post the modifications when I can get some pictures to go with it.
Like I said previously most folks probably don't want to mess with cracking the WUR open. That makes the RPM switch a decent solution if the manual adjustments aren't good enough to move the threshold where in needs to be. |
FWIW, I'd question the 1.35 *reading* - is the reading accurate?
What does the boost gauge indicate? |
I guess it could also be assumed that the overboost protection switch has been disabled if that is indeed the boost you are producing.
Craig,
The only boost gauge I have in the car at the moment is the vdo in tach style, which are well know for their undeniable accuracy, but whilst viewing this gauge, under boost the needle arcs swiftly right, flashes past the 1.0bar mark, and burries itself at "HOLY ****!!!" :D I am climbing under the car tomorrow and will check out the wastegate. Any hints? Should I just remove it entirely, to check actuation? |
...so you *are*possibly at 1.35 bar. She-it, man.
With the AFRs you've shown, I'd hate to see your rings and ring lands. ClINk cLinK^!@ |
Actually - those AFRs aren't so bad for a motor running that boost level - you may still have a physically healthy engine. For now. Time to do it right -
I completely agree! I'm climbing under right now! I'll keep you posted!
Only 4 little 12mm nuts hold the wastegate on. It would be a good idea to remove it and carefully and slowly give it some air pressure and see if the valve opens.
It should retract or move inwards off it's seat. You can use a blow gun, but don't hold it tight against the hole - put it next to the hole and slowly close your fingers around it while letting air escape all around so you don't over pressure it and rip the diaphram. An air pressure regulator turned way down is a good idea if you have one. You only need around 15-16psi to open the valve with a 1 bar spring in there. If it doesn't open you know the diaphram is toast. The valve guide lasts a very long time but eventually wears out too. |
Alright, here are the findings upon inspection:
Line from the top (red arrow) of the WG goes to the inter cooler. Line from the side (yellow arrow) of the WG goes into the engine compartment and terminates to atomospher. Is this proper? http://forums.pelicanparts.com/uploa...1207076606.jpg Is the next step to pull the WG and check for a sticky valve? |
Pulled the WG and started disassembly. I found some cuts in the diaphragm... could these indeed be the source of my overboost problem???
http://forums.pelicanparts.com/uploa...1207082575.jpg |
Could be - I don't know for certain.
Since you have invested a large amount of money (and probably time and effort) I'd purchse the Tial WG. Parts for the factory WG are virtually nonexistent - Now, from the FWIW dept - When I changed to the Tial the actual boost was exactly .1 bar over the spring rate, whereas the factory was exactly on - to the .05. SO with a .8 bar spring and the same B&B headers I am at .9 bar with a .8 bar spring. Tested it with the factory test gauge on the highway- gauge is big as a wall clock ;-) |
Tial F46 should be on the way today. I went with the 0.7bar spring per Jake @ Tial, and Brian Leasks recommendation.
Official word from Tial is that their F46 WG + GHL headers = 0.2bar over spring rate... Now if I can just find a gauge as big as a wall clock! ;-) |
That is opposite of how they should be. The bottom banjo fitting at the bottom, or yellow arrow is the boost pressure line from the intercooler and the top one is vented to atmosphere. If your was hooked up as you listed them than you are actually pressurizing your wastegate to stay closed under boost. You want the boost pressure to lift the valve off it's seat to let some exhaust pressure escape. I bet your car was fast! |
If this is the way it was connected, I'm not surprized you boosted 1.35 bar :eek: You deadheaded the turbo and K-Jet just happend to be able to cope. Now it's time to collect all those piston ring pieces... :( |
Heh heh! Yep scratch that red means yellow and yellow means red! I was trying woman speak!
No, what I am saying is the RPM switch is a good bandaid but does not actually fix the problem, it masks the symptoms.
The problem is that as the WUR ages it goes off spec. In order to recalibrate you need to go inside the WUR and do some adjusting. Once back in spec you re-gain the full spectrum of the threshold adjustment. The RPM switch simply delays the onset of boost by hiding the signal until a preset RPM, effectively overriding the threshold system by shifting the threshold to a point requiring less adjustment. The resulting A/F graph looks better but the WUR is still off spec. |
The stock WUR isn't adjustable to the common man. Brian Leask's device makes it so much easier, and adds different parameters accessible from the outside. |
| All times are GMT -8. The time now is 03:58 AM. |
