Porsche Crest Bolts get loose on turbo flange
The bolts that connect the turbo to the header seems to get loose with the heat. I've tried stacking an extra nut on each bolt as a lock nut. I'm thinking of switching the bolts to fine thread. Any ideas?
Old 04-15-2008, 11:26 PM
are you using locking nuts?
I just went down to the local P-car shop and they had them. They were either copper or brass, cant remeber. make sure you dont use regular metal bolts b/c they will get stuck.
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 04-16-2008, 08:44 AM
cycling has-been
bkreigsr's Avatar
factory calls for:
bolts - 900 074 284 02 - (4 x $11.25 ea @ Pelican)
nuts - 900 910 099 02 - (4 x $3.50 ea)
this is the set up I used on mine with no problems - even after the system has been off/apart 2-3 times
Bill K
Old 04-16-2008, 01:00 PM
David's Avatar
The lock nuts are steel, but they're copper coated. I haven't had one loosen, but just to be safe I replace them rather than reusing.
Old 04-16-2008, 01:03 PM
A fellow Pelacanite
NathanUK's Avatar
My car had the two rear nuts linked. There was not 4 nuts, but 2 nuts and 1 special part that looked like 2 nuts joined together with a piece of metal.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 04-27-2008, 02:13 PM
wcc wcc is offline
wcc's Avatar
I used 'Stover' nuts from the local Mid-State Bolt and Screw place. They are crushed/ovaled nut that is basically a lock nut. Of course I used flat washers as well.
Bill
997.2
Old 04-27-2008, 03:55 PM
A fellow Pelacanite
NathanUK's Avatar
That's how K nuts work too.
Old 05-02-2008, 12:09 PM
