My zr3 laser jammer has arrived
Just got it, has any one here installed one in a 911. I have a turbo slant and it doesn't look like there is any place on the car to install the light emitters. it's designed to work with a car that has a grill. any one else put one of these in?
No FHE. Can you mount it by the oil cooler opening under the bumper?
How did you come to select this particular unit? |
I thought those things didn't work (wrong light spectrum and so forth)......
WHat's a ZR3? I've heard that the Blinder may be the only one that is worth purchasing -
it's supposed to work with my passport radar detector. but the light emitters are bigger than I thought they would be.
I can't see your car, but my friend installs them through the fiberglass and mounted right to the aftermarket bumper/airdam thingy. He said you need a little hole to run the wires and then attached the emmitters right to the firerglass (maybe epoxied in place?). I would try and go on the oil cooler screen if you have one. Either way you go it's better than multiple tickets.
He sells them and says they work. A soon as I install a new bumper/airdam I am going to attach mine to the cooler screen and runit to the 9550i. |
well I am not sure there is room in the oil cooler grille. The emitters are several inches deep and my oil cooler sits directly behind the grille. I really dont want to go cutting holes in the front spoiler.
| All times are GMT -8. The time now is 05:45 PM. |
