935TURBO's Avatar
Cayenne calipers on rear 930....?....
Did anyone tryed this upgrade....?.......I'm looking for adapters.....if it does exist.....
I'm using 996TT discs (330 mm).....
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 04-20-2008, 02:24 PM
A930Rocket's Avatar
Looks like you'll need to machine off the ears and then have an adapter made. I would think a good machine shop could fabe something easy enough.
If those are the rears, what's in the front and what's to keep you from over braking the rear?
Old 04-20-2008, 03:22 PM
935TURBO's Avatar
On front, I've fitted 996TT discs and calipers....and it's really too much.....front is often over braking and rear never block.....?.....some of the PPmembers said that with this front upgrade, that was quite normal....and now, rear tires will be 315/35/17"....so, as the discs will be the same 330 mm as on front, the larger pads will help to equilibrate.....I'm also looking for a dual master cylinder adapter on the mastervac....
the adapter for calipers should be something like that....
Old 04-20-2008, 03:34 PM
Blackbird Pilot
Reaper930's Avatar
Info on Cyanne calipers, this guy has the kits and information needed. No affiliation, etc.
http://goingsuperfast.com/Cayenne-calipers.html
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 04-23-2008, 08:40 AM
935TURBO's Avatar
Thanks Reaper...the worth is that I know this man, I am in touch with him for my EFI conversion....And send him a few clients from FRANCE......I'll ask him....
Old 04-23-2008, 09:40 AM
Me like track days
Craig 930 RS's Avatar
Good luck getting track pads that are worth a crap.........
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 04-23-2008, 07:07 PM
