Registered Abuser
Michelin Sport Cup Pressures on the 930
I am running MPSC I Love em But I have not strayed much pressure wise from what the PO was using, seems to work great.
What are your experiences with pressures running these tires ? 235/40/18 Front 295/30/18 Rear I have been sticking to these pressures Street cold 26 Front 28 Rear Track 28 Front 30 Rear The tires are on the last 20% or their life. I Have almost 2,800 Miles on these since I bought the car. I have fallen in love with the tires. They are not cheap, I bought a replacement set. I want some honest opinions.
MT 930 1987 930 - Gone but not forgotten A man with priorities so far out of whack doesn't deserve such a fine automobile. I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen американский |
Smart quod bastardus
What camber settings are you running?
Reason I ask is that I am wondering if this has alot to do with getting grip outta these tires too. I have started a thread on this exact topic (pressures) already 2 weeks ago or so and have not gotten alot of solid responses indicating reliable answers one way or the other.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
Registered Abuser
Camber
-1.6 Front -1.8 Rear
Registered Abuser
Anything? tips, Suggestions?
Does calling Tirerack help?
I tried and cannot seems to get an answer outta them either. Anyone?
Registered Abuser
Michelin owner's maunal is good info (Found on Tire Rack's Site). I was looking in to some Pelican Insight.
cycling has-been
I've been going out with 30 / 32 and been coming in right at 36 / 38 after the session.
My 77 is only 2,635 lbs and will not heat the tires as quickly as the heavier cars. (tires are mpsc 225/50, 245/45 on 16's) I'm also still searching, and just bought a small pyrometer to try and zero-in on the numbers. Bill K Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
I asked much the same question recently and one person suggested 32 psi for the front and 42psi for the rears.... cold pressure..
Thats where I put them but I don't know if thats optimum for street driving. I have Falcon Azensis 615 on mine, 225/40X18 up front, and 315/30X18 on the rear. |
Let us know what you find out so we can get a ball park pressure that works. Thanks,
