tuning problem
Folks,
I've been struggling with this one for ages (months) in between a million other jobs to get this car back on the road(track). I am sure it is a leaness problem, but I can' t isolate the cause. It runs rough and intermittently on various cylinders on cold start up. Eventually, if you are lucky, after a short period all 6 will kick in (backfiring too). I managed to get it going well enough to take it for a few squirts on the road a day or so ago. There is hestiation and slight bogging down under throttle before boost comes on. Under boost it seemed to go very well, pulling away in 4th like a rocket up to around 100-120 mph before I backed off on the wet greasy road. I now have the advantage of an AFR, and the numbers tell me under boost I was running mid 11's - 12. But off the throttle, or low throttle cruise14's +. It seems by the numbers and feel, the car is running lean at low throttle openings, I keep tuning it richer - and then it is running a bit rich under boost. If I lean the boost end off - it is too lean at idle and low throttle and runs/starts like a pig. My best guess is an air leak. I have spent hours chasing leaks and replaced most everything that looked like leaking. I am about to start over again - I am still loosing about 20 liters/min leakage at 0.5 bar boost pressure. These leaks I presume are air leaks under vacuum (leaness) and boost leaks under pressure. The ones I know of are at the throttle spindle and air screw. Whether they add up to 20 l/min,I don't know. I have checked the AAV, and will check again it is still functioning (was broken first time I checked - fixed). I have checked the cold start valve, and will check again (was broken first time I checked - fixed). I have calibrated the injectors (twice and they are within 1-2 %). I am at the point of having to go over everything I have already been over - often many times, and still not fingering the source of the problem. Have I missed something? Checked WUR pressure function too. It does not seem to respond properly to the mixture screw tuning - there is no sweet spot between rich and lean - normally I can tune to the point where either range just becomes eveident and hit a mid spot which gets you very close. There seems to be no steady mid spot - just a point where it is better than either way from there. Thanks Alan |
I know you checked it, but it still is seeming like a bad WUR, I would try swapping it out if you could.
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
A fellow Pelacanite
Why not just get Brian Leask to mod it. You could get the new UTCIS digital WUR instead.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
