brake piston orientation
As I understand it, the front brakes should have the proud shoulder of the pistons at the lower point - ie bottom - shoulder facing upwards. Have I got this right?, because if I have mine are precisely 180 deg wrong.
I presume this is something to do with pad wear? Mine seem very happy where they are and like to stay put. I can't rotate them - without risk of damaging them. Is there another special tool I have not got (yet)? Alan |
I just rebuilt my calipers and went through this.....here are two pages from the turbo manual.
Dan 88 930 blk/gry |
A fellow Pelacanite
Alan, you may end up having to pop the pistons out. It wasn't a big deal on my 3.2 carrera.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
I guess I need some ATE piston turning pliers - whatever they are - whats the guess my rears are 180 deg out too?
Alan |
You can always "pop" them out, turn them as needed and reisntall.
I was actually only trying to remove the inner deflector dust plate thing. Prefer not to disturb the pistons if possible. Contempalting making a tool to rotate them - but may resort to popping them out.
Thx Alan |
River Rat
Alan,
Buy yourself a brake piston wrench from Genisis, you can easily turn the pistons 180 degrees without having to remove the pistons. http://www.hrpworld.com/googlebase.cfm?key=Genesis%20Brake%20Caliper%20Pis ton%20Removal%20Wrenches&form_prod_id=821,822,373,455,815_1992&action=product BTW, i purchased some new calipers for the front of my 930 recently and did not check the orientation of the pistons. Spent a day at Sebring and the brakes were not working well at all. After returning home, I checked the brake components and found the pistons 180 degrees off. In addition, the brake pads were unevenly worn, enough that they were trashed and replaced with a new set ... live and learn. Gave them a quick spin with the wrench and it's all good again. Good Luck, Dave
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs. |
That's awesome, I didn't know that such thing exist. Amaizing totally amaizing. Thanks!
Piston Diameters
Great looking piston wrench Dave.
Here are the stock 930 caliper pistons diameters if you plan on ordering some wrenches: ![]()
They look very useful for the price. Could have used them. But I could not rotate them - too tight (without the wrench). I pinged them out with compressed air,and reset.
FWIW this was not as simple as I thought - my compressor on full noise could not budge most of them. Finally I cleaned the protruding bits up, lubed them with hydraulic fluid and squeezed them fully in. This did the trick , altho had to be repeated 2-3 times for most. They shoot out at 90 mph no matter how careful . To avoid damaging them I put my hand between them and the clamp holding opposite piston. Very painful. I probably should have used thin wood, but every now and then I like to make a human sacrificial offering to the god called Porsche. Now that I have set them, I probably don't need a clamp - but would have liked one y/day. Regards Alan |
I stuffed a rag in there when I popped mine out.
Very sensible - to use a rag - but much less heroic than trying to catch them.
Alan |
A fellow Pelacanite
I don't have a compressor, I just used the brake pedal to get mine out.
