-   -   930 engine CIS problem, please help (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/416986-930-engine-cis-problem-please-help.html)
NathanUK 07-13-2008 12:32 PM
The WUR has fuel connected to it. I think you mean the electric idle valve that lets extra air into the manifold when the engine is cold.
If you mean the idle valve and connect up this valve before the IC, then hot (non cooled) air will enter the engine. This seems bad.
The inlet charge will be hotter so you wil get a power reduction & increase the likelihood (chance/probability) of detonation. :(
The stock IC has a connection for the electric idle valve (on the cool side of the IC) after the charge has been cooled.
NathanUK 09-07-2008 07:45 AM
Did you ever get this right?
MKEDF 09-13-2008 06:27 PM
Itercooled Duck
Hello
I noticed you are wondering about the conversion on the picture attached to my post...
I happen to fall on ownership of the car on the picture...
The mod was done to fit the intercooler under a Ducktail..
Former owner is Cowtown....do not know why he is not answering any pmīs and sold the car suddenly...
I bouthg it with a dealer in Oceanside, CA..
If I can be of any assistance, let me know
http://forums.pelicanparts.com/uploa...1221355583.jpg
thechiller 09-15-2008 10:46 AM
Hi
NathanUK
well i did get it right i changed the distributor and the rotor, additionally i did remove the airfiler and made a by pass from the intercooler to the warm up regulator. so engine runs quit well, but now i want to go for engine upgrade you can see the link below.
MKEDF
I did a water cooled system, you can see here:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/371584-watercooled-intercooler-system-aircooled-911-a-2.html
Kjell
