 930 Newbie Questions Search has been my friend since I bought my 930 last week.  A number of my questions have been answered.  I knew these cars were more complicated than normally aspirated 911s, but I'm still amazed at the complexity difference. Here's a couple of things that I'm still curious about: 1) I know that a 1 bar w/g spring is a bad idea in an otherwise stock car. I've seen threads indicating that you risk damaging your engine without a bigger turbo and intercooler. My question is: what about a 0.8 bar spring? My car's PO installed it but I have the stock spring (0.6, right?). My car definitely has a stock intercooler and I'm pretty sure it has a stock turbo. Should I go back to the stock spring for the long term health of the engine? 2) The car seems to run a bit after shutting it off. This seems to be more common when the car is warmer. You know: sputter, sputter, rumble....off. Is this normal? 3) I'm following kilodawg's thread about black smoke under heavy acceleration. http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/412396-black-smoke-fuel-heads-turbo-newbie.html?highlight=black+smoke. I can't see it myself, but I'm told mine does the same thing. Any help, experience or comments are appreciated. Todd |
 1) If you are only using the car on the road and not a track you should be fine with 0.8 2) Yes, this is normal and I noticed it too compared to my 3.2 carrera. The idea is all fuel is burnt in the engine. The ignition stays on for say 2 seconds. 3) Get an AFR setup. Have your oil level on the stick halfway between the two marks when hot as oil can get sucked in... |
 .8 is the standard WG spring. Under "heavy acceleration" there is a lot of fuel being burnt, some black smoke is normal. |
| All times are GMT -8. The time now is 07:35 PM. |
