Revs drop slowly when changing gear ... why?
When changing gear, my revs take forever to drop down to idle. (Forever = 2 to 3 seconds.) Not conducive to fast or smooth gear changes!
Idle speed is now also higher (at about 1100-1200). I have been pointed at the vacuum control valve (the "gold" plated one in the center of pic). My other car doesn't have this problem so I swapped the valves over and it made no difference at all. Yes - I have checked that the throttle is fully closing and isn't restricted or stiff in its operation. This condition gradually developed over a period of a month or so a couple of months back. Even though it is now winter (in Western Australia), daytime temperatures are still 60-70F so I don't think that the cold(er) weather is a factor. The car has also developed strange cold starting behaviour which might be related. If I crank motor continuously, it takes forever (5 to 10 seconds) before it crawls into life. I have found that if I just give it a short burst on the starter (about 1 second), I can just catch it firing weakly and bring it up to idle with a little gas. I have checked the fuel pressure accumulator and it holds pressure OK. It always fires up immediately when warm and also on about one out of ten cold starts. Don't you just love intermittent faults!:confused: Any hints for solving one or both problems will be rewarded with a smilie. http://forums.pelicanparts.com/uploa...1216012996.jpg |
vacum leak(AAR?) or springs in the dizzy worn or broken giving too much advance
I'll check this. What's AAR - auto advance & retard?
Check/tighten your intake manifold bolts (17/18psi). Symptoms of vacuum leak. Check hoses next.
Looking at the hose connection plan in the manual, this part looks like it allows air to pass from IC to inlet manifold under certain conditions. I presume this is only when engine is cold? I can understand how this might cause revs to stay high if it was stuck open. I have another car to swap parts from so I'll swap AARs tomorrow to see if this fixes the problem. While it would be nice to identify the problem, my heart is hoping that it is a leaky hose somewhere rather than a $974 part. :( |
By the way, I assume you mean 17/18 ft-lbs ;) |
As kind of stated you might want to check that your vacuum hoses are connected to the dizzy at both ends and that the timing is set correctly.
Along with other comments here, it spurred me into action tonight to sort out my suspect throttle bypass valve (AKA AAR). I was going to swap it with one from another car but based on Rarly's experience above, I decided to replace it with a bit of broomstick instead! The difference is amazing. Revs drop just nicely instead of hanging there at a zillion rpm for what seems like minutes. After I had test-run my wooden AAR, I went back in and checked the tension on the inlet manifold bolts as suggested by Rarly and found that all were very light. To get up to 18ft-lb I had to go between half and one turn on all bolts. This didn't make any further difference to driveability but it clearly indicates that this is a potential trouble spot. I couldn't see or hear any air leaks and all other hoses look OK so it seems that problem is fixed. Don't panic - I will replace the broomstick with something more appropriate now that I know the solution. Thanks for your help, Bill |
Interesting idea with the broomstick. I just used large bolts. Although it is a throttle bypass valve in function, what you have removed there is the AAR, not the throttle bypass valve, refered to previously as the vacuum control valve. The throttle bypass valve is the goldish canister attached to the BOV and intake manifold. Put the AAR back on and see if your problem still exists. |
Has anyone here used nylon lock nuts to keep the manifold nuts from loosening up? I am putting my manifold on tonight and am thinking that this might be a good idea since it seems to be a common occurence. Any downside?
I think the problem here it is more to do with gradual compression of gaskets and the phenolic injector blocks than nuts coming loose. |
Ah ha Bill... that makes better sense. I think I may go with the nylocks and use aluminum washers to offset the weight gain :)
Everyone seems to have different names for these parts ... http://forums.pelicanparts.com/uploa...1216172765.jpg PART A is called ... Throttle bypass valve (by Rarly & others here) * Decel valve (Pelican Parts) Vacuum Control Valve (Porsche manual, page 26.37) Aux air valve (Porsche manual, page 25.18) PART B is called ... Aux air regulator (Pelican Parts) Throttle bypass valve (Porsche manual, page 26.37) * Aux air valve (Porsche manual, page 25.10) Just for the record, I have removed PART B and it solved my problem of the engine holding its revs for too long on gear changes. It doesn't drop instantly, but it is heaps better than it was. PART A is still in place. I swapped this part with one from another car last week and it didn't make any difference. Maybe they are both not working. :( It seems that PART A can also be scrapped without too much drama. Re-reading previous posts, it seems like deleting this one will also cause revs to drop off even faster. I'll try this in a few days and post results. Looking at Rarly's engine, it seems that both A and B have been deleted - correct? I would love to get a clear description of all the parts that control our engines (what do they actually do and why do they do it). Can anyone direct me to 930 Engine Management 101? Bill |
Careful... "A" was never refferred to as a throttle bypass valve. "A" is and always will be the decel valve. B is simply an idle adjustment for when the engine is cold. BMW and Mercedes call them ICV's on the new fangled fancy injection them thar folks use. Basically is allows air to bypass the throttle plate thereby increasing the revs of the engine. It is like a mini throttle plate that is controlled by electronics. The way I best understood it was like a manual choke on an old engine. And yes, it is really expensive. The folks that get rid of them are the folks that don't live in cold climates and they just hold the accelerator open a little more until the car warms up and that valve woudl have closed anyway.
As for A... someone else will have to explain why the he!! that rusty piece of crap is on our engines in the first place. Although it seems to be like an old school carburator dash pot... not allowing the throttle to snap closed and instead easing the motor back down to idle. I just wish the plating on it was a little better and Bosch did not require a second mortgage for a new one. |
Hehe, yes the name game is confusing. A warm up regulator (WUR) is actually a fuel pressure control regulator in function with warm up as but one of the many jobs it performs. Piss poor naming scheme.
I would not be too quick to blame the problem on "B" the AAR. You did 2 things at once when you tightened the intake bolts. Put the AAR back on and see what happens. There are half a dozen devices on the 930 CIS that bypass the throttle. The AAR, AAV, BOV, Decel Valve, and the various thermo time switches and valves. It's a freakin' vacuum leak waiting to happen. As for "A" the throttle bypass or decel valve, that device is in place to route air around the throttle body during the high vacuum event of abruptly lifting the throttle. It does this to prevent the engine from stumbling. Your right foot can take the place of all of these devices. They all allow the car to be easier to drive under different conditions. When I removed all that stuff I lived in Illinois. It gets pretty cold there in the winter. No problems starting and driving the car. All that is on my engine is the CSV (cold start valve), Fuel Head and WUR. |
The second part of your reply raises another issue. When some ICs are fitted, they replace the BOV housing and the attached decel valve. I had a B6 IC on this car some months back and it didn't seem to be a major problem with throttle shut-off. It was abrupt, and I learned to drive with it, but it did make for interesting sphincter clenching moments during sudden throttle-off situations on bends! I hadn't really thought about the effect of this valve before because when I fitted the IC, I took so much stuff out that I didn't really identify the change in throttle action with the absent decel valve - *****, I didn't even know how to spell decel valve then!! It's definitely going to get plugged soon, even if its just to see what happens. I am currently rebuilding the engine in my #2 car (fixing oil leaks, stiff throwout bearing and about a million dollars worth of other "while I'm in there" stuff) and the B6 IC will end up on that car, along with other improvements I am picking up from this forum. |
I actually blocked the AAR and test run and got a favourable result. THEN I went back in and checked the manifold nuts as you had suggested. They weren't tight, but don't seem to have been leaking because nothing changed after I did that. As I mentioned in last post, I will block the decel valve as well, even if it is just to see what effect it has. Thanks again. |
Just to put this issue to bed, I can confirm definitively, positively and absolutely that it is the DECEL VALVE that is the cause of revs not dropping very fast on up-shift (as Rarly and others already knew!!).
I confirmed this to myself by clamping the vacuum line to the decel valve with a pair of vice grips and the result was instant. No more hanging revs while I'm trying to get into the next gear. My exercise with the broomstick in the AAR circuit seemed to help, but had no where near the same effect as disabling the decel valve. With both valves disabled, idle revs when cold were about 500 so I retired the broomstick and put the AAR back and everthing is just fine. :D Once I've made up a special bracket to support the vicegrips, the job will be complete (it looks a bit ordinary with them just hanging on the hose). SmileWavy |
If you must leave the decel valve mounted on your engine at least put a rubber nipple on the vac port feeding it and one the port on the face of the valve.
I can see a set of vice grips going through your engine fan ... |
Hey, vice grips are expensive. There's no way I'd want to damage them in the fan! :eek: |
You wouldn't believe what I've seen.
Glad you are more on the ball than that. Unfortunately humor doesn't translate well with the typed word. I started a firestorm on a thread about the C2T digi-gage setup due to misinterpretation of my style of humor. Guess we'll have to wait for the web to go live view, ha! |
Great reading, all of this. Thanks for all your contributions.
So the moral of the story is to leave "B", the "AAR", in there? I love losing unecessary crap, yoinking that would be great but not if I need it here in chilly CT. D'oh - I'm "that guy" who plugged the decel valve (with a golf tee and a zip tie - I'm so high fashion)... but left the vacuum port wide open. Now that you type it Brian capping it seems so obvious. Again, d'oh. All seems fine as is, I'll cap it next time I'm in there I guess. Funny - for some reason, before even reading this thread (I was only in the BOV delete thread until today), I saw the manifold nuts there staring me in the face (I'm sans A/C) and opted to check tension - a couple were pretty darn loose. Well, relatively at least. Nice! Speaking of sans A/C... I'd LOVE to loose that huge hunka alum. that used to mount the compressor. Quick glance shows the exhaust strap bracket mounted to it. Anyone loose this? Any tips? I'll be posting up my Jenny Craig results sometime soon - it is ohso gratifying looking at the MOUNTAIN of f'n crap I've pulled off the arse of the biatch thus far. Gotta be 150lbs. Keep the great ideas flowing gents. ps. and yes - I too fell for the vice grips bit... too funny. |
I believe that you could quickly make two little spacers that could replace the spacing that the A/C bracket provides. Although, the a/c bracket could not have weighed more than 2 lbs.
Ahhh! Kindred spirits.
I think I'm in love again. Just love this place. |
YOU CAN TAKE THE BRACKET OFF AND CUT THE PART OFF THAT GOES FROM THE BOTTOM WHERE THE EXHAUST MOUNTS AND COMES INTO THE ENGINE COMPARTMENT TO THE TOP OF THE MOTOR. Thats what I did , Looks very clean. I'm glad to see that your rev problem is solved , another thing you may consider is cleaning the air plate under the air box . My car had the same problem loose bolts and a dirty air plate , tightened bolts and cleaned my plate no problem. Just a thought
Thanks DSP - will do. 2 whole pounds!?!?!? I'll take it! 8-) Heck, 2lbs here there everywhere - it adds up. I so cannot wait to put my large box 'o JUNK on the scale and weigh that bish. So gratifying - like giving the pig an enormous diharretic... <plop> - aahhhhhhhhhhhhhhhhhhh... Again, to yoink the AAV or to not yoink the AAV - that is the question... Bueller? I bet it's gotta be 0.25lbs!!! 8-) |
If you remove the whole engine and trans you can save like 800 pounds :)
Yank the AAV.
Take advantage of the component design of CIS. You can put the AAV back in the winter if it bothers you. |
How exactly can I delete the decel valve / throttle bypass valve on a 965?
I also would like to enjoy more pops and faster drop of revs while shifting. Is the easiest way to unplug the hose going from the Bosch Bypass valve to the Decel Valve? Or do I have to plug both connecting points after taking that hose out?? Thanks for any advice! |
You should be able to remove the small vacuum line that goes to it and plug it. There is no need to plug the device itself at all.
Do not muddle the Blow Off / Recirculation Valve with the Decel Valve as you could damage your turbo. |
Better yet, if you have an aftermarket recirculation valve (bov) tune it with the different springs that should have been supplied with the bov. If you have a OE bov, replace it as the spring is too weak or the diaphram is ruptured. I had the hanging RPM and I cured it by installing the intermediate spring supplied with my Forge bov. The weaker spring popped open too quickly, causing a big pressure impulse to be pushed into the intake and causing the RPMs to hang for a second, which is like an eternity. The heavier spring allows for a slower opening and a more controlled air dump to the intake. |
The question asked by gogomobil is about the decel valve, not the BOV.
The two are a system; it makes no sense to talk about one without the other. |
I see what you are saying and you are correct, but the question was how to remove the decel valve. All 3 connections need to be blanked or capped off.
Why do you suggest having the BOV venting to atmosphere? |
I just installed a Forge Splitter bov. It vents to both the i/c and the atmosphere. I bought it so that the revs won't hang under boost and it does a great job of venting. Now the revs drop immediately. Granted I could have got rid of the decel valve, blocked off all the ports on the i/c and had the bov vent to atmosphere but this was a quick and easy way to prove out my theory that the initial spike of high pressure air coupled with the inertia of the bov and decel valve were causing the hanging revs. The nice thing about the spliter valve is that it comes with a block-off cap so it can be made to function like either a recirc valve or a bov. |
Venting the BOV to atmosphere is not recommended as it upsets the metering flap of the CIS.
I guess some of the boosted air will enter the engine due to the electrically heated idle control valve. So, venting to atmosphere would cause the revs to drop faster. |
The only reason I can think that the metering flap might get upset is that it will feel neglected :D When the air flow across the plate goes to 0, it shuts the fuel off. End of story. It will do that if the bov is shoving air into the intake manifold behind the plate or dumping air to atmosphere because everything is occurring downstream of the plate. |
I think the theory is that when the bov allows bypass the turbo can continue to spin although there is no exhaust to power it so it will eventually slow down. This should help keep the turbo spooled while changing gear for instance.
Surely when you dump to atmosphere the turbo will also continue to spin but it will pull air through the metering plate causing extra unneeded fuel to get injected as though you just opened the throttle. The turbo once again will eventually slow down. No bov/recirc should cause the turbo to stop spinning pretty quickly and put it under a lot of unnecessary strain. |
High pressure air that gets trapped between the air sensor plate and the throttle plate during a throttle closed event has to be vented somewhere. The factory chose to send it back into the engine for the following reasons (1) emissions as the overrun of the metering plate and extra fuel getting dumped to the engine will be burnt (2) to prevent compressor stall (3) noise abatement. So, the pressure spike that occurs when the throttle butterfly closes gets vented into the engine. Problem is, there's inertia in that air moving into the engine, inertia in the bov and decel valve so they don't open instantaneously, inertia in the vacuum signal going to both valves and hysteresis in the vacuum signal line and air feed lines (rubber flexing). Dump the high pressure air to atmosphere and only the inertia of the bov alone is present. Hysteresis is no longer a consideration. When the bov relieves the pressure it closes as the vacuum signal won't overcome the spring force alone in the valve (the bov is designed and tuned so that boost pressure and vacuum pressure > spring force. Therefore no further air will be ingested when the pressure in the intake between the metering plate and the throttle plate drops below the a value that is a little less than full boost pressure. I agree that to remove or disable the bov will cause bad things to happen (1) the compressor gets hammered and stalls (2) the metering plate oscillates. I'm not advocating removing or disabling the bov, just changing where it vents to. The metering plate won't know the difference but the driver will because the engine speed will drop much more quickly as less air has to get pumped through the engine when the throttle plate closes. |
