Picture of the Turbo Oil Pump
Anyone have a picture of the turbo oil return pump? Preferably internal pics, but will take any I can get right now.
Brett |
Turbo scavenge pump?
Sorry, Yes turbo scavenge pump. Thanks for the pics.
Brett |
A fellow Pelacanite
Never seen one before, thanks for the pics.
I'm a little confused... Where are the gears or the impeller? EDIT: I see where the gears are now. Any chance of a pic of them?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg Last edited by NathanUK; 07-23-2008 at 01:43 PM.. |
Cool piece of engineering. Does anyone know if this will fit on any engine, or does the camshaft need a special adapter?
DZ12,935K3,934,2.8RSR Ducati 900ss/GhezziBrian STW dzugautomobili.com |
Fits only the 930 engine (unless you mod the cam and cam tower?).
7.0:1 > 11.3:1 > 7.0:1
Inside of pump... gears are about 7/8" dia and equally long.
I just picked up a Sportomatic oil pump that runs off the cam on the back of the motor. I think I may see if I can use it to scavenge the turbos. It looks like it is as capable as the 930 pump. The pics I have show the one on the 935 and it only has one pump. How is it plumbed into both turbos? A splitter?
Brett |
resident samsquamch
I thought this was an interesting solution...not to get off topic.
Neil Harvey (Performance Developments) and I discussed this back when I was rebuilding my engine and was exploring twin plug options. Some of the 956 and 962 race cars utiltized the cam to drive a distributor. In Neil's application, he used an ignition module from Link and dual coils. The advance in the stock dizzy is locked down, utilizing the trigger, and the Link module/ECU controls the timing...fully programable. So this is a scavenge pump modified to accept a basic 911 "E" or "T" cap and rotor. It's used in conjunction with your stock dizzy...two dizzys ![]() ![]() ![]() ![]() ![]() ![]() ![]()
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
A fellow Pelacanite
Nice pics guys, thanks.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
It would probably be cheaper just to go twin coils and run one crank mounted trigger wheel, but it is a really neat concept. The 959 had a dizzy driven of each bank of the engine.
Brett |
resident samsquamch
Yeah there's lots of ways to fire 12 plugs. I just thought it was interesting in that this part had a dual role: scavenge pump and dizzy...
