-   -   930 Turbo spec diff US vs RDW (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/425316-930-turbo-spec-diff-us-vs-rdw.html)
cal007 08-15-2008 05:07 AM
Hello, I recently bought another 930 Turbo (own 3 overall).
I know there is the hp difference to the EU model with 260HP. the US version has only 245hp.
Do anyone of you know which changes exactly cause the hp difference. Is it only the thermal reactor or also another set-up in the control unit.
Did anyone change the set-up to the 260hp version?
Thank you for any comments.
cal
930turbo 08-15-2008 06:29 AM
The only difference between the two that caused a reduction in power is the exhaust. Compression, cams, timing and fuel delivery remains the same.
DSPTurtle 08-15-2008 07:04 AM
I thought the Euro CIS was different then the USA CIS???
RarlyL8 08-15-2008 09:49 PM
The 260HP Euro is the 3.0L from '76/7. The '78- on Euro had 300HP.
NathanUK 08-16-2008 01:50 AM
It is, but the AFR's don't differ at WOT.
930turbo 08-16-2008 04:52 AM
The black iron fuel distributor was identical for the US & ROW. The European conversion was unnecessary until the US aluminum version was installed in '86. Even this version was capable of making plenty of power, the limitations came mostly from the amount of air volumn the stock intake could manage. The beauty of the 930 is the start life as being very fast and can be modified to completely rediculous. My car is nearly stock and it can generate wheel spin in second gear.
