930 Turbo spec diff US vs RDW
Hello, I recently bought another 930 Turbo (own 3 overall).
I know there is the hp difference to the EU model with 260HP. the US version has only 245hp.
Do anyone of you know which changes exactly cause the hp difference. Is it only the thermal reactor or also another set-up in the control unit.
Did anyone change the set-up to the 260hp version?
Thank you for any comments.
cal
Old 08-15-2008, 05:07 AM
930turbo's Avatar
The only difference between the two that caused a reduction in power is the exhaust. Compression, cams, timing and fuel delivery remains the same.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 08-15-2008, 06:29 AM
DSPTurtle's Avatar
I thought the Euro CIS was different then the USA CIS???
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 08-15-2008, 07:04 AM
Crotchety Old Bastard
RarlyL8's Avatar
The 260HP Euro is the 3.0L from '76/7. The '78- on Euro had 300HP.
Old 08-15-2008, 09:49 PM
A fellow Pelacanite
NathanUK's Avatar
It is, but the AFR's don't differ at WOT.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 08-16-2008, 01:50 AM
930turbo's Avatar
The black iron fuel distributor was identical for the US & ROW. The European conversion was unnecessary until the US aluminum version was installed in '86. Even this version was capable of making plenty of power, the limitations came mostly from the amount of air volumn the stock intake could manage. The beauty of the 930 is the start life as being very fast and can be modified to completely rediculous. My car is nearly stock and it can generate wheel spin in second gear.
Old 08-16-2008, 04:52 AM
