Safety relay bypass
I would like to bypass the "safety relay" on a 930 Turbo 3 litre 1977 model, to check if some systems are working, as I suspect this relay is dud ( no spare available to swap out at this point) Part number is 93061711701. Which pins should be bridged to override it? ( taking the round pin as being at 12 o'clock)
Is this the so called overboost relay? Can anyone tell me what the black relay on the rear panel ( in photo) controls? In the past when I had a problem with the car cutting out, the mechanic bridges this relay out, someone told me it has nothing to do with the ignition, so i am a bit puzzled. I also took a photo of the front fuse box, the first relay is red, and again I am told that there should possibly be another red relay in the holder next to it, or failing that, on the rear panel with the CDI unit, which currently has a black one! Who is correct?http://forums.pelicanparts.com/uploa...1218908262.jpg |
I think the black relay you have pictured with the white marks on it is the 'overboost switch relay' this toggles the fuel pumps on and off thanks to the overboost switch mounted in the recirc assy on a stock car.
I believe C is the ignition delay relay, this holds the ignition on for a few secs after you turn off at the key.
As for fuel pump relays, yes there are two and both should be red.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/424622-930-fuel-pump-relay-wiring-once-all.html |
| All times are GMT -8. The time now is 06:27 PM. |
