Blitzkrieg
Just went for a nice brisk drive to Snoqualmie falls here in Seattle area, the first signs of fall, nice dense cold air, everything going perfect until I decide to wick it up abit to pass a couple cars and when I shift from 3rd to 4th, the damn throttle sticks wide open and lets out a nice "auspuff" and scares the s$%t out of me. I noticed that the revs kind of hang in between shifts lately, but this time it stuck wide open. Is this a sticky cable or decel valve? I had to tap throttle pedal a few times to get it unstuck from the floor, made for a very exciting pass though!!
Driver
Yikes. Of all the cars in which to have a sticking throttle! I can't offer the sage advice like others on this board, but I'd look at the throttle cable/linkage, first. Or maybe the car is just trying to tell you something? Wink wink.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Have someone tickle the accelerator pedal for you as you listen in the engine compartment. I had the brazing on the throttle linkeage break, and the open space hung up on the connector every once in a while....eventually fell off leaving me with idle speed only. Take off the intercooler and see if you can check the linkeage back there.
1987 factory Slantnosed 930 Cabriolet/Guard's red 2002 Midnight Blue 996TT X50 1999 Iris Blue 996 (Dash fire burned and totalled 9/07) |
I had this problem before, right after changing the clutch cable.
Have you made any changes/adjustment to the clutch lately? Seems I adjusted it too much towards the clevis end at the pedal assembly, this was causing the cable to flex as it dove over the throttle rocker at the engine and holding the throttle at whatever it was at when the clutch peddle was pushed.
Rod... 2010 - 997 PDK, Black on Black, Daily driver. 1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony! |
E-85 sippin drunk
I had this happen to me as I was changing from 3rd to forth gear at full boost. Scared the ever lovin ***** out of me!!! It turned out to be in the throttle linkage up front, right where the linkage goes into the center tunnel.
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Blitzkrieg
[QUOTE=turbobrat930;4194063]I had this happen to me as I was changing from 3rd to forth gear at full boost. Scared the ever lovin ***** out of me!!! It turned out to be in the throttle linkage up front, right where the linkage goes into the center tunnel.[/QUOTE I will check linkage first thing in morning and start there. Haven't messed with anything lately, except added aluminum throttle pedal a month ago. I guess its time to get out the WD40 and oil the throttle linkage and rebuild pedal cluster.
Btw: Your brother Bryan is a blast!
E-85 sippin drunk
No, This was after I went to the G-50/50 setup, so I have a hydrauilic clutch. IIRC, part of the linkage got stuck on the side of the tunnel, right as it goes into the tunnel.
and yea, he (Bry)can be a handful at times.... thanks for keeping an eye on him...LOL
Wer bremst verliert
Its very easy to have something hang up your linkage. I had it happen on entry to turn 9 at Eastern Creek, a hairpin. I nearly soiled myself.
On a side note, anyone want to opine as to why Porsche stuck with the mechanical linkage for so long? I am trying to figure out a linkage for the supercharger setup and I'm about to give up and go to a cable.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
