tial wastegates
Are the tial 46mm wastegates a bolt on item or is fab work required?
Sorry for the questions, but I have not found the local Maryland area 930 owners to learn from yet. I appreciate all the tips this forum provides.
Emery 1988 930 coupe - Silver Metallic TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
If using stock headers, you will need to buy the 46mm Tial that is specifically designed for 930's The difference is the cooling vanes are shaved giving them more of a boxed shape to clear the stock headers (the others are more round). Other than that it is bolt on. Just don't get to crazy with the boost springs till you take care of some other stuff (fuel tuning, bigger intercooler etc)
John A. 1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.) 05 Boxster S: For the Track. 06 Dodge Ram 2500 Power Wagon: Tow Vehicle |
I don't believe thats true. I sell a good amount of the WG's and I rarly sell the 930 version but as cheap insurance for $40 more ($490total) you know it is bolt on
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
+1 This is my understanding as well. My Tial is has the cooling fins shaved on the one side to clear the valve cover. If you have aftermarket exhaust, then it's not a problem.
Right....kuz on the other hand, I'm using the SSI headers and the Tial has the rounded fins which clear the headers just fine.....of course I also have RarlyL8's custom Y pipe too. But when using the stock equipment, the shaved fins are definitely something to consider before buying one.
MB11 should know....he builds exhaust systems along with RarlyL8.
1987 factory Slantnosed 930 Cabriolet/Guard's red 2002 Midnight Blue 996TT X50 1999 Iris Blue 996 (Dash fire burned and totalled 9/07) Last edited by Chuck Jones; 11-05-2008 at 09:47 PM.. |
There are a number of us around.. spread out around the beltway on the MD, DC, & VA sides. Number of very competent shops around as well. Paul
RGruppe #180 So many cars.. so little time!! |
Ben, I bought a Tial WG from you for my '87 930 (OEM heat exchangers) and had to grind off quite a bit of fin for it to clear an ajoining pipe. It must've been the "generic" Tial WG. For 930 guys, I think it's better to sell them the 930-specific unit (they've got lottsa money anyway).
Scott - 1987 930: 3.45L Supertec engine w/GT3 crank, California Motor Sports upgraded 930 trans, modified suspension, Zuffenhaus 9's and 11's, black on black..."The Black (Financial) Hole"
I run the regular round Tial, but do have custom SSI headers that give me more than enough room at the WG location.
I also recently fitted standard tial style wastegate to friends car and had to cut away some material on the fins so wastegate would fit to standard exhaust system,b&b style headers etc standard tial wastegate should be fine i believe.
SP Autobahn www.spautobahn.co.uk Porsche inspector for Peter Morgan UK http://www.porscheinspections.com/ "92" 964 turbo,Modified and recently rebuilt using all ARP hardware.. Purpose built fuel controller set up to acheive perfect fuel curve on CIS inj. Last edited by stup; 11-06-2008 at 09:56 AM.. |
resident samsquamch
I run the "standard" 46mm Tial on mine and it fit perfectly for my B&B headers and my OBX headers. However, I have to remove it to get my lower valve cover off. It's not resting against the cover or anything, there just isn't enough clearence to slip the cover out once it's loose. One of these days, I'll take the grinder to a couple of the upper fins...
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
Yeah, once you swap to a aftermarket exhaust with the flat side Tial, you can remove the valve cover with out removing the WG.
Forced Induction Junkie
But then, I only take the covers off once a year in the Winter to inspect the valve train and adjust the valve clearance. No biggie.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
resident samsquamch
Yeah, same here.
Ditto my experience. Just a few minutes on the grinder and she fits fine.
'89 911 M491+Turbo '90 964 C2 '89 944 Turbo '88 928S4 |
To answer the question if you buy the 930 specific Wg then it is a bolt on regardless.
I had a set of SSI headers with heat that I had RarlyL8 design a Y pipe for....and the 46mm Tial fit on there with plenty of room as you can see in the picture. This setup has been great, but it doesn't solve the issue for your stock system.
1987 factory Slantnosed 930 Cabriolet/Guard's red 2002 Midnight Blue 996TT X50 1999 Iris Blue 996 (Dash fire burned and totalled 9/07) |
