utcis-pt base map for 930?
Does anyone have a good base map for the 930, to use with the utcis digital wur?
There is a link on their site for a 930 base map, but the link is bad. It looks like their download section links are all bad (can't get the updates to download, either). I'll call them Monday to see what the deal is, but in the meantime I figured I'd ask if anyone else had a base map I could get a copy of. Thanks
Emery 1988 930 coupe - Silver Metallic TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ... ![]() |
All you have to do is call and talk to Frank and he can take over your computer and in just load you one in the map of your controler that will be a real close starting point . The one that is in the unit is not bad,depending on mods. and if you have means of monitering AFR, I would not be afraid of trying it just to get a base. you can drive the car around with the one that is in it from factory, but I wouldn't get carried away without monitering AFR. In any event you will love the unit. Good luck
UnwiredTools
Map Links Fixed
The Maps should be downloadable now - we moved to another web server and I guess I missed this. If there are any other links not working, please let me know!
Frank |
Thanks for fixing the link!
I'll give it a try tonight when I get home from work.
