I think it's because his IC is off for work.
On a side note, (and not to hijack) all the local 930's should meet up sometime around spring. For a killer group photo, or at least grab a few beers somewhere. Imagine riding down the road and seeing like 5 930's just parked outside some restaurant. |
And 965's...
That is a great idea. I just joined the Potomac PCA, but I have not been to any events yet. Maybe we could start our own splinter group. Count me in... Mark |
I have learned lots from these forums and finally I have something to offer.... I had a RUF intercooler kit and here is the instruction sheet that came with it. Hopefully it helps identify where things go.http://forums.pelicanparts.com/uploa...1238242002.jpg
I also had a RUF air filter housing kit. Here is that instruction sheet.... http://forums.pelicanparts.com/uploa...1238242141.jpg |
hello flatspin...,
thanks for sharing this rare sheets with us! I have build the connection pipe, here is a easy drawing if someone needs it. units are milimeter! the connector for the bypass valve you need to size according to your needs. http://www.alumex.de/930/Saugrrdrw.jpg which will result in this more or less: http://www.alumex.de/930/Saugrr.jpg thanks Falk |
