part number help?
I need the part number for the turbo bracket to engine mount for a 930 please advise ..
Do you mean 930 107 113 01 ??
I don't know is it the braket that is between the turbo and the muffler in a stock application?
930 123 121 05 is the correct part number according to the PET.
http://forums.pelicanparts.com/uploa...1227916113.jpg |
What I am using it for is simply a clocking device so I can build up a HE for stock bolt on for turbo cars in keeping turbos in the stock location |
930-123-121-05 930-123-921-05 ; 930.66- S M148 The latter bracket is for the 330BHP engine with a K27-7006 turbocharger. This engine is the one used in the Special Wishes and 930 SE cars before 1987. The nomenclature, 930.66, is the engine series available for the option. M148, "Engine with increased efficiency", is the option code for the 930 SE cars, I believe. The earlier PET had all all the part numbers for the Special Wishes Slantnose cars, but you had to search like crazy to find them. |
My '91 has the K27 turbo. The number listed for it is 930 123 121 05, which is the number that goes all the way back to '78. That makes sense to me as the 930 engine in the 965 was carried over by Porsche from '89. |
... but the K27 was not a carry over from the 930, it is specific to the 965.
What Ben needs is the 3LDZ bracket. That is the one all 930's have and must be used for fitment purposes when designing exhaust components. It is curious that the 965 lists the same part number for the turbo bracket as the 930. As illistrated above, the turbos are different and the K27 requires a bracket mod when installed to replace the stock 3LDZ on a 930. The post-turbo exhaust system on the 965 is completely different than that of the 930, so it stands to reason that if the same bracket is used on both 930/965 then the turbo is oriented slightly different on the 965 than on the 930 and the 965 exhaust system is designed to accommodate. That also would explain why my mufflers fit differently on a 965. Interesting ... |
Not that there will be a great number of people ordering a replacement bracket for their 965 turbo's, I think they're in for a disappointment if they do. That bracket is not going to work on a K27 without the mods mentioned. It stands to reason the bracket is different as the cold and hot sides of the K27 are dimensionally larger. It's got to be a typo error.
I can't find my old PET, but it listed the correct part # for those K-27 equipped engines. |
I think our host sells it.
| All times are GMT -8. The time now is 07:43 PM. |
