tacho signal wire
Guys,
I'm trying (unsucessfully) to install a digi WUR. One of the things I need is to hook into the Tacho sensor wire. The engine is an 87 930. I have a wiring diag, but I don't know which wire is the sensor wire. Can I use the coil? Thx Alan |
I connected the neg coil terminal to the tach signal wire and the postive coil terminal to the switched voltage wire on my rpm module.
Emery 1988 930 coupe - Silver Metallic TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ... ![]() |
My unit is a bit different - it only has the one tach signal wire.
Will running off the -ve coil suffice for the tach signal. Is this where the tach picks it up from? If so, that will work fine. (PS - there is an update on the UT site - you can convert to the single wire pick up). Regards Alan |
I think the tach picks up from the CDI box or from somewhere else, but the negative coil post is OK, too. It's working for my version of the DWUR. You can always move it somewhere else later.
I believe there is a black wire with a purple stripe near the CDI box. There should be a black in-line fuse looking connect if I recall corectly. You can tap in there.
OK guys, thanks.
Looks like the black violet one out of the CDI box. That relates to my wiring diag. Not proceeding at moment, now, unit is not functioning. Oddly, UT tell me I don't need the tacho input for digi WUR. Can't work that out. Regards Alan |
![]() ![]() Alan,I don't know if this will help, but here it one on a 965. Good luck . It is real easy to install and use. |
Got it.
Thanks. I like the way you have mounted the box. Alan |
