-   -   Decel valve delete question (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/447172-decel-valve-delete-question.html)
gogomobil 12-19-2008 07:50 AM
In order to get a faster rpm drop in between shifts and some more pops, bangs and flames I deleted the decel valve from my 965. I understood from the previous threads that all 3 hoses need to be plugged. The smallest hose is running from the BOV to the left side of the decel valve, but in between is a T-piece and an extension runs from there to the throttle body. shall I leave the hose from the BOV connected to the throttle body or not?
Thanks in advance SmileWavy
AFM744 12-19-2008 08:08 AM
Definitely. The Bypass Valve will not operate unless actuated by manifold vacuum. Compressor stall and even badder things can happen if the bypass valve is disabled.
gogomobil 12-19-2008 08:10 AM
perfect, thanks for the help! :)
