Decel valve delete question
In order to get a faster rpm drop in between shifts and some more pops, bangs and flames I deleted the decel valve from my 965. I understood from the previous threads that all 3 hoses need to be plugged. The smallest hose is running from the BOV to the left side of the decel valve, but in between is a T-piece and an extension runs from there to the throttle body. shall I leave the hose from the BOV connected to the throttle body or not?
Thanks in advance
Old 12-19-2008, 07:50 AM
Cynical Misanthrope
AFM744's Avatar
Send a message via Yahoo to AFM744
Definitely. The Bypass Valve will not operate unless actuated by manifold vacuum. Compressor stall and even badder things can happen if the bypass valve is disabled.
X-1, AFM744, Jon, '92 C2 Turbo
JE 8:1 pistons, 964 cams, 38mm intakes ported/polished/twinplugged, ARP hardware, B&B headers/exhaust, 355whp. Full-blown GT35R 3.2 intake EFI pending...
Where my misspent time and money is currently going.
Old 12-19-2008, 08:08 AM
perfect, thanks for the help!
Old 12-19-2008, 08:10 AM
