3.0 vs. 3.3 distributor
I have a 3.0 turbo with a broken distributor. I bought a distributor to a 3.3 turbo. Is it possible to get the newer one to fit my car? Im suspecting that they rotate in different directions. I might just get parts from the newer and fit them in my old broken one.
Any thoughts?
Old 01-07-2009, 12:16 PM
Smart quod bastardus
fredmeister's Avatar
Think they spin the same way for both engines....I believe the turbos to '89 and 911SC both spin counterclockwise but I am not certain.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 01-07-2009, 01:08 PM
I have been researching this for a couple of hours now and I´m getting even more sure about the different directions. If I compere my old (the new hasnt arrived) with pictures I found in the forum I can se that the drive gear is not the same. And also the weights inside look like they are mounted in opposit directions. I guess I have to just swap the broken parts.
Old 01-07-2009, 01:15 PM
930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
how did the car run with the defective distributor ? just curious
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 01-07-2009, 03:28 PM
"A left-turning distributor is installed on 3.3 liter turbocharged engines" was taken from page 28-14 of my Porsche turbo service manual.
Old 01-07-2009, 11:21 PM
juicersr's Avatar
Does that mean clockwise?
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
Old 01-07-2009, 11:34 PM
Sounds like counterclockwise to me.
Old 01-08-2009, 03:25 AM
It runned just fine. But with 2000rpm idle. When I set idle to normal I only got 15degree advance at 4000rpm. This was not a big problem to fix. But while taking the distributor apart I broke the magnetic disk.
Old 01-08-2009, 03:28 AM
Turboo934's Avatar
3.0 dizzy is clockwise 3.3 is counter clockwise.
juicersr's Avatar
Sorry to hijack, but does anyone know if the curve of the 3.0 Turbo completely different than a N/A 3.0? I will be dropping some low compression pistons in my spare 3.0SC motor soon for a turbo project and just curious.
dzugautomobili.com
Old 01-08-2009, 04:41 AM
Another way to check rotation is look at the way the wires are layed out on the distributor cap. Firing order should be consistent with all years of flat 6 so 1-6-2-4-3-5
see link here: http://autorepair.about.com/library/firing_orders/bl-fo-11477.htm
So look at your cap and trace the wires. This will tell you which way it rotates. Unless your wire layout was reversed but then I don't think it would have run at all.
Only other explanation is the 76-77 model 3.0 liter turbos were unique and spun clockwise.
Old 01-08-2009, 06:12 AM
Turboo934's Avatar
75-77 were unique, like the Carrera 3.0 same crank as a2.7.The SC 3.0 had a larger main bearing as did the 3.3.
Old 01-08-2009, 07:05 AM
