gumba's Avatar
slantnose oil line interference
Anyone else getting front oil cooler line interference in the slant nose. My lines go between the back of the pop up headlight and the tire. When the wheel is turned to the left I have about 1-1/2" clearance. I'm getting rubbing under hard turning or while in a turn I hit a dip. I don't see any other way to run the lines in the fender well. I'm considering running the lines inside the trunk to by pass this. I would bring them in where the hard lines end, then back out by the cooler.
How did the factory deal with this when they mounted the cooler in the front?
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 02-01-2009, 08:02 AM
A930Rocket's Avatar
I want to say the factory did run them through the trunk.
Old 02-01-2009, 10:34 AM
Forced Induction Junkie
WERK I's Avatar
They did in the Special Wishes cars with the high output engines. However, I still get an occasional rub right where the lines connect when the wheel is full lock (to the right, I believe). Didn't have it until I went to 17" Fikse 8" fronts with 235/45 tires.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-01-2009, 10:51 AM
gumba's Avatar
Did they use the stock hard lines then put a 22.5d bend or coupler where it comes into the trunk?
I'm currently using the 245/35/17's on 9x17's.
Harold
Old 02-01-2009, 11:05 AM
WERK I's Avatar
Yes, you know where the couplers are for the short lines going to the Carrera front wheelwell? They attached the hoses there and then redirected them through the trunk, then down through the front bulkhead connecting to the cooler.
Dave
Old 02-01-2009, 11:14 AM
