R.I.P.
drmatera's Avatar
"Fluttering" mechanical boost gauge
my factory boost gauge doesn't work so i installed a mechanical gauge. Under WOT it flutters pretty wildly between 11-13psi. If I accelerate slowly and gradually build some boost it is nice and steady till i foor it. So at part throttle making 6-7psi it's steady, but at full boost it's fluttering like a scared cat. Does this sound like a bad wastegate or maybe a boost leak (aka: o-ring problem)? I have had the intercooler off several times and the o-rings appear ok. I don't hear any hissing sounds under boost indicating a vacuum/boost leak either.
Old 09-05-2009, 01:50 PM
Sounds like a manual or electronic boost valve thats not working right or is chattering could do that.. if there's one installed.
might be a leaking injector block? The origonal bakelite ones eventually crack and leak.
Old 09-05-2009, 02:25 PM
R.I.P.
drmatera's Avatar
no boost controller on the car. It's supposed to have a 1 bar spring in the gate but it nevers makes over 13psi, in fact i think it only hits 13psi on the gauge do to the flutter
Old 09-05-2009, 02:38 PM
mark houghton's Avatar
Outside of the gauge fluctuation, does she run nice and smooth...no misfiring/hessitation etc.? No other symptoms other than the gauge doing the funky chicken?
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 09-05-2009, 05:48 PM
A930Rocket's Avatar
What's it tied into?
Old 09-05-2009, 06:16 PM
R.I.P.
drmatera's Avatar
the car runs pretty smooth at WOT, although it seems to feel alittle soft till it hits 5000rpm at which time it feels like it makes another 30-40hp. The one brief time i had my wide band on it the car would go full rich (10.1) when i floored it but i didn't watch it all the way to redline. So maybe it's running to rich causing the boost to flutter. I didn't see if the boost gauge calmed down once the engine was over 5000rpm as i was then concentrating on the tach and road. i need another set of eyes, or maybe a dyno appointment. There's only 2 of them on my street
Old 09-05-2009, 08:45 PM
R.I.P.
drmatera's Avatar
oh, the boost gauge is sourced right at the intake manifold.
Old 09-05-2009, 08:46 PM
beepbeep's Avatar
Something lifts off and leaks out, acting as a pop-off valve? I would start with inspecting intercooler O-rings.
Thank you for your time,
Old 09-06-2009, 02:48 AM
