Spark plug question
What kind of plugs are you guys running in your modded EFI'd street motors?
Great Question
I asked my tech this today and he said use 930 spec plugs. Anyone care to chime in?
They're too cold and expensive for street use... BTDT :(
NGK Iridiums, BPR8ES and DPR8EA (or something like that)
Are you tracking it or DE days.....this may make a difference to run a cooler plug than for street.
Good question. |
My understanding is if it's purely for street use, then a warmer plug is OK to use as it won't foul as quickly.
For track events, definitely use a 3 or 4 heat range. Just curious to know what range you guys are using on the street without fouling. |
- 1978 930 3.3 engine - twin-plugged, ported, polished & flowed heads - dual 6 plug EDIS ignition - 8:1 compression ratio - 964 cams - 50# injectors - K27-7200 turbo - B&B headers - Megasquirt II v3.0 |
| All times are GMT -8. The time now is 11:59 PM. |
