Twins are more fun!
JMA-RUF's Avatar
Spark plug question
What kind of plugs are you guys running in your modded EFI'd street motors?
James
Carrera TT
(3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's)
Old 01-27-2009, 02:26 PM
MiamiTurbo
Great Question
I asked my tech this today and he said use 930 spec plugs. Anyone care to chime in?
wanabe911 owner
1974 914 2156cc project
2005 Lotus Elise Original owner
2002 996TT Tip
Old 01-27-2009, 06:24 PM
Twins are more fun!
JMA-RUF's Avatar
They're too cold and expensive for street use... BTDT
James
Carrera TT
Old 01-27-2009, 06:35 PM
David's Avatar
NGK Iridiums, BPR8ES and DPR8EA (or something like that)
Old 01-27-2009, 06:45 PM
Smart quod bastardus
fredmeister's Avatar
Are you tracking it or DE days.....this may make a difference to run a cooler plug than for street.
Good question.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 01-28-2009, 11:30 AM
Twins are more fun!
JMA-RUF's Avatar
My understanding is if it's purely for street use, then a warmer plug is OK to use as it won't foul as quickly.
For track events, definitely use a 3 or 4 heat range.
Just curious to know what range you guys are using on the street without fouling.
James
Carrera TT
Old 01-29-2009, 02:34 PM
mppickett's Avatar
I've been running for a couple of years of street use on NGK BKR7EIX plugs with no fouling. This is one range colder than stock 993 turbo OEM. Here are my basic specs:
- 1978 930 3.3 engine
- twin-plugged, ported, polished & flowed heads
- dual 6 plug EDIS ignition
- 8:1 compression ratio
- 964 cams
- 50# injectors
- K27-7200 turbo
- B&B headers
- Megasquirt II v3.0
07 Audi A4 2.0T Cabriolet - Black/Black (sold)
96 993 C2 Cabriolet - Arena Red/Tan (sold)
82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold)
58 DKW Universal - Baby Crap Yellow/Beige (sold)
Old 01-29-2009, 04:04 PM
