-   -   Temp sensor(s) for CSV (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/454634-temp-sensor-s-csv.html)
TroyN 01-31-2009 06:14 PM
The PET shows two sensors, one on each side of the engine, is this the case? In my SC there is just one sensor, on the driver's side. I want to at least temporarily disable my cold-start valve, which again in the SC you can do by pulling a wire at the sensor. I know I can pull the wire at the CSV but it's not too easily accessed. Thanks.
TroyN 02-02-2009 11:10 AM
Don't everyone answer at once! ;)
I found I could just pull the wire from the CSV. Much easier in the turbo than the SC (impossible without dropping the engine), especially with the stock airbox assembly gone.
