-   -   AFR Tutorial, Please !!! (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/456060-afr-tutorial-please.html)
Ronnie's.930 02-08-2009 10:55 AM
Hello,
I am in the process of installing, and learning how to use, an LM2 . . . what are the "good numbers" with regard to AFRs for idle, low RPM, midrange, WFO, etc ???
I know this has been discussed extensively in the past, but it is hard to put all this together via the search function (info scattered everywhere) . . .
Thank you !!!
Ronnie
930gt-40r 02-08-2009 04:28 PM
Well under full throttle, I would like to see 11.2-11.8 (depending on boost level and heat)
Under cruising, you may want 14.5- 15.5 or maybe a little more depending on load
Idle should be a less than cruising
Some people will argue these numbers, I always try to keep it fat under throttle and as lean as possible under crusing (better gas mileage, less oil contamonation, cleaner motor, less wearing)
laughac 02-08-2009 04:33 PM
I've asked similar questions but have only heard general answers so far. It would be great to see the perfect AFR curve on a chart.
A lean idle is said to be good, but above that I can only assume that 11.8 is ideal.
gogomobil 02-09-2009 02:51 AM
Originally Posted by 930gt-40r (Post 4473216)
well under full throttle, i would like to see 11.2-11.8 (depending on boost level and heat)
under cruising, you may want 14.5- 15.5 or maybe a little more depending on load
idle should be a less than cruising
some people will argue these numbers, i always try to keep it fat under throttle and as lean as possible under crusing (better gas mileage, less oil contamonation, cleaner motor, less wearing)
+1
