cycling has-been
77 930 3 pin or 6 pin?
simple question?
sorry. I bought a spare CD unit from a 78 930 that is 6 pin without verifying whether mine is 3 pin or 6 pin. help thanks Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 03-05-2009 at 04:44 AM.. |
I think that the early 930's are 8 pin.
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
cycling has-been
cool, look for my 6 pin FS on the used parts forum*
I didn't know there was an 8 pin thanks Bill K *after I pull the disconnect a bunch of pipes, tubes, relays, and wires to check the actual teminal
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 03-05-2009 at 10:43 AM.. |
cycling has-been
73 911T MFI, 76 912E, 77 Turbo Carrera |
But wait.....I'm running with an MSD6AL, and it doesn't have any pins at all! Man, I'm screwed and didn't even know it.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
cycling has-been
you're confused ?!
I've been carrying this thing around in my track box as a spare and just now realized that it might not be the correct one. Bill K
Bill,
If your 8 pin fails and you can't find another one, you can rewire your harness and use the 6 pin. Or go with MSD. If you are into originality then you are ***** out of luck.
cycling has-been
thanks all
I looked in the repair manual at the wiring diagram and then under the lid to confirm, and it is an 8 pin CDI. They are really different looking then the 6 or 3 pin - huge duh after 31 years of faithful service from the oem unit, I guess I should be looking at the MSD as an alternative. Bill K
