82sc turbo project
No turning back now, going with a precision turbo t series 6157, which specs out close to a k27, using a stock waste gate with a home fabbed .5 bar spring and a boost controller,intercooler is a re-worked stock 944 front mount with piping to be fabbed, ignition is an MSD 6BTL which will pull up to 3 degrees of timing per lb of boost. Hope
to be done by late January and hoping for 225-240 horsepower to the wheels!
1982 911 SC----SOON TO BE TURBO 911 SC |
Tim,
Love it !!!!! Keep us posted. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. |
Interesting project.
Blow through or suck through? CIS or EFI? Last edited by 911st; 12-12-2010 at 07:12 PM.. |
An SC with 240 to the wheels?
Shouldn't be allowed! ![]()
Interesting project. -------thanx, $1500. Budget Project!
Blow through or suck through? --blow thru CIS or EFI?= keeping CIS for now had the turbo from a previous build, purchased new exhaust housing------$210.00 New MSD Ignition------------------------------------------------------------------------$350.00 INNOVATE Air fuel gauge and wide band 02 sensor------------------------------$222.00 stock 944 front mount intercooler from ebay---------------------------------------$75.00 used j pipe from this board------------------------------------------------------------$100.00 Boost gauge to replace clock from ebay--------------------------------------------$125.00 stock rebuilt 930 wastegate from ebay---------------------------------------------$250.00 Air intake left over from a previous turbo build----------------------free oil feed and return lines-------------------------------------------------to be made yet exhaust---------------------------------------------------------------------to be made yet boost controller-----------------------------------------------------to be purchased yet intercooler pipes to be custom made---------------------------cost of pipes I am sure there will be more to "BUST THE BUDGET"
Tim,
Sounds like a good plan. I like the idea of a blow through CIS. Could just put an air filter on the turbo like one of the 3.2 conversion guys here to keep it simple. Though that scares some. Bet you get over 240whp at .5 bar once it is dialed in. |
.5 bar
With a .5 bar spring and a boost controller I will be able to turn boost up slowly as I watch AFR'S.
Locally I can pump 100 octane unleaded and or 110 octane leaded right into the car, so I hope to be able to run closer to .9 bar safely.
Wastegate done!
WASTEGATE IS DONE! DIALED IN AT JUST OVER 6 P.S.I.
Blow thru airbox
UNFINISHED BUT CLOSE JUST NEED TO INSTALL INTERCOOLER TUBE AND I AM GOING TO PUT A FEW VACUUM/ BOOST PORTS ON IT FOR THE MSD BOX AND MAYBE SOMETHING ELSE THE FUTURE.
Brando
I'll watch
Turbo powa! 1977 911s. it's cool |
What are you using for a boost gauge, is it a direct fit for the clock? How did you modify the WG spring to 6lbs?
to fletcher0780
I found a greddy boost gauge that was exact fit for clock replacement, slid right in perfectly. As far as wastegate spring, we will have parts available soon to modify porsche wastegates to any boost level from 3psi up.
Tim
Love it!
Can you post more pics of the air box? I just tried this with my 2.7 but blew a piston. Now in the process of installing a 3.3. 1st step is to verify the condition of the 3.3 by running it with the proven 2.7. setup.
2000 Boxster S 2004 330ci convertible 1978 450 SLC 1924 Model T Ford touring Fleet of Ford Buses, Sedans, SUVs and Limos |
Parts source for converting Porsche wastegate to adjustable?
wastegate
Converts your wastegate to an adjustable one or sets your wastegate to desired boost. I chose to go low boost on the wastegate and run a boost controller to turn it up.
B.sweet racing 574-780-3485 ask for brian
Please provide a model, part number, or size of this boost gauge. I'm also interested in the spring selection.
smoothed bumper
rear bumper is now smoothed painted and reinstalled so i can now move on to making custom exhaust !
Great Project!!!
One suggestion-Your MSD-COIL-OIL Filled- In your Pic- IS UPSIDE DOWN. I had mine the same way for years, until I started having misses. It leaked ever so lightly. Walt Last edited by wjfk32; 03-23-2011 at 06:12 AM.. |
I bet you will be closer to 300hp, i was running 8-9lbs of boost with the use of a 7th injector on my 79 engine which was putting out around 350. I had my MSD BTM retard set at just under 1 with stock timing.
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 |
Roland 930 Turbo '81 Too many modifications to list |
