torresmd's Avatar
Removal of rear trailing arm bushings
How do I do this. Do I need to press them out? I searched but could not find anything on the rear bushings.
Thanks,
1998 993 C2S Guards Red/Black
1990 964 C2 RWB project car
2016 GT3RS White Daily driver
2018 Lamborghini Performante Gegio Telesto
Old 02-08-2011, 01:43 PM
River Rat
Dave 86 930 Fl's Avatar
Bushing Removal
Thanks,
Steve,
You seem to be following in my recent foot steps ... I did the Elephant suspension replacement and they have procedures on their website that detail the process fairly well. But if I had to do it all over again, I'd take the control arms to a shop and have the old bushings pressed out and the new pressed in. It's not a terribly difficult job to do, but the risk of breaking a control arm that costs ~$1800 is possible.
Regards, Dave
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 02-08-2011, 01:59 PM
beancounter
jwasbury's Avatar
If you want to simply put fresh factory rubber in there, its very easy to remove/replace.
If you're looking to upgrade to a mono-ball cartridge, you need to get the steel inserts out. I carefully cut mine with a hacksaw and dremel tool:
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 02-08-2011, 02:26 PM
torresmd's Avatar
I am upgrading to mono-balls. And yes those steel inserts were quite the challenge. I got it done and the mono-balls will go in tomorrow. Thanks for all the advice.
Old 02-08-2011, 05:54 PM
