DIY alignment
I installed a bump steer kit since the car is low and I was getting bump steer.
I also raised the rear about 1/2".
I raised the left front corner 1/2" since that side was lower. The car is less stable now of course.
The car pulls to the right now when driving and not braking.
The toe was out/positive quite a bit so I adjusted it in negative. The manual says to adjust the front toe to +15' which is strange since I thought you needed negative toe. Am I reading it wrong?
Also is there a good way to check this instead of a measuring tape? It is hard to get a good reading since you can only reach the lower part of the tires.
Could I have messed up the rear toe when raising the rear. I loosened the two large bolts in the middle of the swing arm to make the adjustment.
Old 04-20-2009, 04:20 PM
e170drvr's Avatar
I know it can be done DIY but from what I have read it is a monumental pain in the azz. My reply is useless to you since you have already started the work, but you might consider hedging your loss here, and get your car over to a pro with a rack and get it corner balanced while your at it. Life is too short and these cars handle too good to settle for anything short of a proper alignment. I know there are a bunch of guys on here that do it themselves, but it is real time consuming and a lot of trial and error. Just my .02.
Eric
87 930 Coupe Red, K27S, Kokeln IC, Rarlyl8 Headers system, Tial 46MM, .9 Bar. "Lola"
81 911SC Coupe Guards Red, Stock. "Zippy"
Old 04-20-2009, 06:39 PM
A930Rocket's Avatar
^^^^+930^^^^
Old 04-20-2009, 07:53 PM
mark houghton's Avatar
Do it (or screw it up) yourself
A person by the name of Ray Scruggs apparently sold a short book on the subject some years ago, and I believe our gracious host carried it for awhile. Here's a place to get a pdf copy I found somewhere. Have not tried it myself......yet.
http://mothena.com/Documents/Porsche%20911alignment.PDF
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 04-20-2009, 08:24 PM
Eric
I agree and I will do that soon. I just wanted to get it close before hand.
Old 04-20-2009, 08:53 PM
Hey, that's a cool link. Thanks for that!
Old 04-20-2009, 08:55 PM
Smart quod bastardus
fredmeister's Avatar
Thanks great info.
I have been doing this for years but never documented it. Basically using the Smart Racing strings method without buying all that expensive equipment.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 04-21-2009, 06:23 AM
Max Sluiter
Flieger's Avatar
Seen at the Long Beach ALMS Sportscar Race about 3 hours before the rollout onto the track:
I think the photos say it all. More photos and video here: http://www.flickr.com/photos/max_911_fahrer/
Old 04-21-2009, 11:43 AM
