AFR and/or EGT gauge recommendations
We tried to install an AFX AFR meter in my '77. It boots when the key is in the on position and seems to work properly until the engine actually starts. Once the engine starts the gauge keeps freezing as if it does not like the power source. We were about to run it directly to the battery but discovered that voltage drops to 11.5 volts even at the battery at idle.
Today the battery and alternator system passed testing. Another 911 is having similar problems with an AFR gauge, but his symptoms are less frequent. Since I don't sit idling other than at red lights I've decided to try a different AFR system. 1. Can anyone recommend another AFR meter? 2. Can anyone tell me what exhaust temp is normal for a turbo-charged 911? I'm a strong believer in Exhaust Gas Temp gauges but need some baseline data. Thanks, in advance, Chris
2000 Boxster S 2004 330ci convertible 1978 450 SLC 1924 Model T Ford touring Fleet of Ford Buses, Sedans, SUVs and Limos |
After the next project
AFR recommendation
I have one of these and I like it.
http://www.innovatemotorsports.com/products.php Mine is the permanent install XD-16. I had some issues with mine (all my fault). I didn't have an adequate ground and had the power source to a constant, not the ignition (on/off) which I needed. Also, your volts are low. At the battery it should be around 12.5 - 13.2 at idle. I would check all of your electrical connections. I would say all of your issues will be related to that 11.5 volts. I'm guessing that EGT's should not be more than 1400 but I would guess it is much lower. I am only guessing here. I'm sure someone will chime in and help. Best of luck, Bryan |
I use the PLX multi display gauge for boost, AFR and EGT, very precise and quick responding gauge, I really like it:
http://www.youtube.com/watch?v=PbtvC39I9Qs for this mod you need to send your tach to dave, Dave@C2turbo.com |
Dave
I forgot about Dave. I purchased my AFR gage before I was familiar with this set up. He does a very nice job. I would go that route if I was doing it all over again.
Thanks for posting gogomobil. Bryan |
I got an AEM wideband and a Defi EGT gage- they work pretty well for me. I know the Defi's are a little ricer, but they are cool because they have a playback function that becomes very usefull in diagnostics
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
I use an Innovate DB AFR gauge connected to the LC-1 controller. Likewise, I had issues with power supply and had to run a larger switched positive lead from the fuse panel to the gauge.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
I've used the Zeitronix ZT-2 for the past 4yrs and still like it. You can log AFR, EGT, Boost and others. Several display options, or just use your laptop for logging. It even has a separate module that can be programmed as a warning, or turning off/on different devices.
http://www.zeitronix.com/ Disclaimer: I'm not affiliated with Zeitronix, blah, blah.......
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
