Wo ist die Rennstrecke?
Using CDI, I am using all 115mj of energy in one cylinder. That's nearly twice the energy in each cylinder, IF you assume all the wasted spark energy is going into one cylinder - but it's not - it's shared between two. One more thing. I can gap my plugs out to .032 and use Iridium - its a big hot spark. With wasted spark, the maximum gap was .024 before it misfired. The Link ECU has an ignition test function where you can test each channel - just pull a plug, turn the car on and test the channel. With the wasted spark, the plugs would sizzle with each test fire. Pull a plug using CDI and test the channel, you'll get a sharp crack you can easily hear in the cockpit. I always wanted a G50/50 tranny for this car because 4 gears doesn't do well on technical tracks. Now I want to hit a track with the new spark (and presumed increase in torque) and see if it made as big a difference as I feel on the street. I hope to dyno this config in a couple of weeks. I just found out that a local shop in Peachtree City has a dyno. Unfortunately its a dynojet but it should give me a reference point. |
Don, thanks for the explanation.
Now I just need to figure out how to get the extra three ignition signals from my ECU to the engine since I've already used all 47 pins on the bulkhead connector. I guess I'll have to give up on my dream of having NOS injection
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Forced Induction Junkie
Don,
Is the M&W 6 channel CDI system a multi-spark at lower revs like other CDI systems? Thanks,
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
I don't believe any of the M&W CDI's are multi spark. They are of such high quality and power that I don't think it would add much over what it already does.
I just wish they had a 6 channel available when I built my engine. Unfortunately they didn't so I'm running a 4 channel M&W with 3 channels split to make 6. Even if someone is still using a distributer, I recommend using a single channel M&W CDI vs other options if they don't mind the additional cost over Bosch, Permatune, or MSD. I think a single channel M&W CDI is about $600 but you can make a harness to connect the M&W straight into the 6 pin connector on the stock Porsche harness.
Navin Johnson
Don,
Before this conversion your car was batch fire/waste spark? The reason I ask is when I was setting up the LinkPlus Gen 1 EFI on my car six or seven years ago.. I was tempted to go the CDI or COP route but getting the car on track won over any more development... Did you change the trigger that you are using? did you add a CAS (cam angle sensor) to define sync and home events? I looked at the schematics for the M&W Pro 16 S3 and it appears you only need 3 ignition channels to fire the coils...Sounds like since you are still using the 2 output coils it is still waste spark not true sequential? or am I missing something? I think I'm going to call Neil tomorrow and order one of these..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
It was wasted spark using 2 three channel ignitors to the same coils.
Just caught this thread. It's been awhile, but I has two of the single CDI units on my 930. The difference was huge. Before I had Electromotive on the car. Although back then there was not so many choices, the M&W system made the car come alive. For quite sometime i thought the car was as good as it could be. I soon found out just how much performnace I was losing.
I have not had the need for the multi channel units, but if they are as good as the single units, you made a great choice. Someone posted if they have multi spark. The single unit did I know for sure. It was wired so it gave the multi spark on starting and idle and as soon as the boost came in it when to high power, which doubled the output. I cannot remember exactly how it was wired to do this, but thro EFI systems, switching is easy. Even on CIS engines without EFI, I think a simple boost switch would work. Don, I would love to know how the car feels under acceleration and how the throttle response is compared to before. That was my biggest gain. Compared to how the CDI made the car respond, the Electromotive seemed really lazy and soft and mushy. You have stated its better, but can you quantify how myuch better yours is. In my case I would say it was greater than 50% better. It made a new car out of mine. Have a great drive. |
I spent most of the morning driving the car and fine tuning the fuel maps. A couple of very noticeable things:
Idle - what a huge difference. Using the same map, the idle is now nailed. I mean, the idle doesn't move more than a couple rpm and the engine is dead solid. Its now a toss-up between my Acura and the 930 on which idles smoother. Another big improvement is throttle response, and I don't mean just off idle. While adjusting the fuel table today, I had to pass a car was slowing me down. So, while behind them I noticed the TPS showing 7.5% at 50mph in 3rd gear. I pressed the pedal slightly and the car just flat pulled - I looked at the TPS and it showed 15%. It was pulling as if I had pressed the throttle halfway to the floor. Very very cool. And the biggest improvement is something that is the hardest to explain. In fact, I called Neil today on his cell phone just to talk about it. When I get into boost and the car takes off, it is the smoothest acceleration I've ever felt in this car. I've driven a lot of newer P-cars at the track and always liked how smooth they were. Prior to the change, I would explain the acceleration as contained violence - raw power. Now, the power is so smooth and refined. Under WOT now, the power is deceiving - I used to gauge the power/speed by the feeling of the car. Can't do that now. I looked down on a WOT pull for a data log and wholly crap - 120. Did not feel that one coming. Anyway, the car is very different and I am really enjoying it all over again. |
Way cool.
Hey Don,
Your comments about how smooth the car is, tells me you have done a good job in the mapping. Great job. And how good the EFI system you have is. |
I wish we could get Geoffrey in on this discussion, FYI I used to run the M&W setup but I now use the DENSO coil near plug setup from motec and the ECU controls the spark which allows for a little over boosting while still operating safely.
Lincoln Phillip 87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound. Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs. "the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker |
SCHNELE,
Are the Denso Coils the CDI type or do they have Igniters built in? |
The igniters are built in.
DonE,
I completely agree with your evaluation. We use the same coils and M&W CDIs, and they work extremely well. We think they are the best CDIs made and now use them exclusively. Looking forward to your dynos. Hope you can keep traction on that Dynojet with that monster!
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
