ATTN: 930 WIZARDS...Help Me Solve This!
Hey guys. I'm hoping you can help me trouble shoot a persistent problem that I am having with my '87 930. The car will die on me (stall) while driving and will not restart. However, after it sits for a couple of hours, it will start up no problem at all. The problem can occur 5 minutes into the drive or 30 minutes etc. Sometimes it will stutter before the stall and sometimes just cut-off. My wrench has been unable to get the problem to surface while at the shop, and so, has been unable to solve/fix it. He gave me a substitute ignition box, fuel relays, and alligator clip to jump the #6 fuse to try when it happened again. It happened again last night and none of these remedies worked.
Any thoughts?
When I first bought my car it had a similar problem, replaced the ignition and coil with an MSD 6AL and it worked fine after that.
The Coil is suspect if a cool down fixes the problem. They are only $50 and easy to replace.
David |
The next thing I would check would be the overboost sensor. Easy to check without throwing any more money at the problem. When the problem occurs again, simply ground the wire going to the sensor. If the car starts, you have found the problem. Let us know if this is the issue,
Dave |
Thanks for the thoughts guys! Keep 'em coming.
Check those other items first and then check fuel pressure, not WUR pressure, but fuel pressure. Your fuel pump may be dying. Do you live in a hot climate? Could be vapor lock if the pump can't maintain enough pressure.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
1998 993 C2S Guards Red/Black 1990 964 C2 RWB project car 2016 GT3RS White Daily driver 2018 Lamborghini Performante Gegio Telesto |
Bill 997.2 |
Unplug the sensor and the pumps won't run. Hook the wire to ground and you've bypassed the thing.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
My car is dead in my garage right now. I turn the key to position 2 and no humming of the fuel pumps. So this has happened two months ago and my mechanic replaced the relay and fuel pump. Two days ago the car won't start. So I need to get the car to my mechanic. I was planning on getting a tow but if I can bypass the sensor and get the car to start that would be great. Problem is I need pics. Connect this wire here etc. Help! I hate getting my car towed.
A picture tells a thousand words....
Thanks Mark, that is good info. My car is on the tow truck as we speak. If this happens again, maybe I will try this.
Mark, that's a great post. Thanks for taking the time to do that. I love these forums. Information is power, brotha!
I hate to keep asking silly questions but in the second picture showing the jump, do those wires go anywhere or is that just a loop? Cannot really tell from the pic. I just want to be clear on this, just in case I try this some day.
I believe a "jump" is simply a loop that directly connects the two contact points.
1987 factory Slantnosed 930 Cabriolet/Guard's red 2002 Midnight Blue 996TT X50 1999 Iris Blue 996 (Dash fire burned and totalled 9/07) |
Boost Freak
If all else fails, my car had the same symptoms.... the ignition went bad, made the car stall and that's when I went to a MSD which fixed the prob.
82 Porsche 930 Euro, black, 31K miles. Factory stock other than k27 turbo, B&B headers, GHL exhaust, Tial F40, 1 bar wastegate, MSD 6A ignition, 8" and 9" Fuch upgrade, H4 Xenon headlamps and a 930S steering wheel.
Yep, just a loop (it's about 10" longer than it needs to be). That little red wire resides in my glove box for emergencies.
Also, one of the fuel pumps relay or air lock due to "may be" bad gas...
