where can I purchase a 0.9 bar spring??
where can I purchase a 0.9 bar spring for the stock wastgate ?
Thanks |
Twins are more fun!
James Carrera TT (3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's) |
do I need 38 or 44 MM for the stock wastgate?
thanks |
Twins are more fun!
46mm
Metal Guru
I believe that Tial wastegate springs will not work in a factory wastegate.
Spring sizes available for the factory wastegate are .7 bar , .8 bar, 1 bar and 1.2 bar. The .7 and .8 wastegate springs are, to my knowledge, only available as used. The 1 and 1.2 bar springs are available from Weltmeister through Performance Products. To achieve .9 bar you will have to do one of the following: (1) Buy a Tial 46 mm wastegate as James has stated and select the correct spring that yields .9 bar on a boost gauge (on my 965 with a stock exhaust that was a .8 bar spring). (2) Find a factory .7 or .8 bar spring, install it, a mechanical boost controller and a mechanical boost gauge and adjust until you achieve .9 bar.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
