Is it alwas cylinder 2 or 5 that goes?
Has any one ever seen any cylinder fail on a 930 other than # 2 & 5?
The thought is they have the most direct air path so they might get more air flow and thus run a little more lean and that they are the only cylinders in the middle so they might run hotter.
Old 03-10-2009, 04:36 PM
bahnzai's Avatar
Yep, mine was cylinder #1. Although #2 also had shattered compression rings, #1 is the one that let go...
Danny
'83 930 track beast
'73 914-6 3.6
'70 914-6 (sold)
'74 TR-6
Old 03-10-2009, 05:24 PM
beancounter
jwasbury's Avatar
I've heard number 6 runs hot since its right next to the oil cooler.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 03-10-2009, 06:17 PM
Ingenieur
This is an interesting question that I would like to hear more about. I could swear that I saw a picture once that showed 930 cylinders with some of the fins removed, mainly on one side. I believe the intention was to make some of the cylinders run hotter so that, for emissions purposes, all the cylinders would run the same temperature. Has anyone ever seen a 930 motor (3.0 or 3.3) with this feature?
Old 03-10-2009, 06:38 PM
Wer bremst verliert
JohnJL's Avatar
I have a CHT on each cylinder. #4 always around 10 deg hotter.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-10-2009, 11:12 PM
Lightbulb
I wonder if running different heat rated plugs would make a difference or maybe too much of a difference. Just a thought...
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 03-10-2009, 11:20 PM
John,
Excellent on monitering each jug.
Have you done a fuel quantity test to see it it is getting the same amount delivery as the others?
Old 03-11-2009, 06:33 AM
sudo apt-get purge 930
equality72521's Avatar
All 930 cylinders (at least 3.3, not sure about 3.0) have fins only on the bottom side.
--clutch-monkey
Old 03-11-2009, 06:37 AM
With the 91 C2 Turbo the fins returned.
The 3.4, 3.5 and RUF performance cylinders were all fined. Porsche took the fins off and went to small intake ports mostly for emissions.
Old 03-11-2009, 06:43 AM
Wer bremst verliert
JohnJL's Avatar
No, I dont have a method for testing AFR on each cylinder. 10 degrees could also be within the instrument tolerances.
Old 03-11-2009, 03:46 PM
Here is a great thread on checking that fuel deliver is the same to each cylinder.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/461843-meter-head-flow-adjustment-question-post4536761.html#post4536761
Old 03-11-2009, 03:58 PM
Tinkering Pays!!
mooney265's Avatar
john,
what is the operating temp. range [average] you see with your CHTs?
I have one sensor installed and see 285 - 300 F
Shannon
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 06-12-2009, 06:01 PM
mark houghton's Avatar
By my count from feedback so far, suspected cylinders are 1, 2, 4, 5, 6. I guess that leaves just #3 as being safe. I bet if we wait long enough, someone will come up with that one as well, which means that none are more prone than any others to "fail".
This after my own statistical regression and probability analyses of available data, of course
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 06-12-2009, 07:13 PM
930gt-40r's Avatar
hahaha
I have heard (not scene) that number 1 and 4 get hit the hardest because of the vents for the heat taking away cooling for those two cylinders. I am going to post another thread on this issue because I need advice as well...
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 06-13-2009, 06:42 AM
