Blitzkrieg
jly535's Avatar
Wooo Hooo!
I won a stock intercooler for $35 shipped! Now I'm going to have to figure out how to make it work with a '77 930.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=160342982037
77' 930
10' BMW F800GS
08' Tundra
Old 06-25-2009, 11:38 AM
you really haven't won anything!
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 06-25-2009, 02:44 PM
Sorry I didn't mean to sound so condescending but if you are going to go through the trouble of mounting an intercooler please do yourself a favor and get a proper one.
Lincoln Phillip
Old 06-25-2009, 02:46 PM
mark houghton's Avatar
Hell of a deal. I've seen these listed for anywhere from what you paid to $700 (people thinking they have a gold mine on their hands because of the word Porsche). But with stock intercoolers, there is a surplus floating around out there because of the many people who have upgraded to more serious cooling.
Lincoln's suggestion is something you might consider only if you intend someday to slide down that slippery slope of performance modifications where you would benefit from a larger intercooler. If you're pretty much staying stock everywhere else, then the stock IC will work just fine.
My stock IC is spending a lonely retirement on the shelf in my shop. Actually, I'm holding out for the day when the 930's become rare breeds and someone is just itching to return one to stock configuration....so I can sell it for $700.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 06-25-2009, 03:07 PM
You need the manifold for the 3,3 because there is a different angle from the 77 to the 78 intercooler. Its usually just easier to buy the whole injection system and slap it on.
Bruce
Old 06-25-2009, 03:17 PM
As Bruce is saying, you need an intercooler made for a 76/77. Andial used to make one and B&B might but I do not recall.
Old 06-25-2009, 04:45 PM
full quack's Avatar
Send a message via Yahoo to full quack
I thought '76-77 did not have intercoolers at all?
Why could you not, just simply get the top section of a '78-'79 3.0 turbo intake manifold and fab from there?
Hell, once you get the intercooler connected to the intake manifold, it's just tubing & hoses from that point on,
Mark
Old 06-25-2009, 08:28 PM
Blitzkrieg
jly535's Avatar
Mark
That's what I figured. A stock intercooler is better then none at all, and I don't plan on going for more power. At the very least I'm sure I can make my $ back.
I turbocharged my BMW 535is so I'm used to making things work.
77' 930
10' BMW F800GS
08' Tundra
Old 06-25-2009, 10:35 PM
Crotchety Old Bastard
RarlyL8's Avatar
I probably have a dozen stock intercoolers stuffed in a corner of the shop. They are worth about what you paid.
This is not a matter of buying the later up-pipe and down-pipe, the stock '78-on 930 intercooler will not fit the '76/7 intake. The angle of the throttle body is different.
Old 06-26-2009, 04:00 AM
Linc - OMG...that was damn funny!
Yasin
Old 06-26-2009, 04:54 AM
Jesper's Avatar
Mark
The 930 1975-1976 and 1977 didn't have a stock intercooler! They had, US models 245 BHP and EU 260 BHP. The first Turbocharged 930 with stock intercooler and 300 BHP came in 1978.
Best regards
Jesper
Old 06-27-2009, 07:05 AM
260 for a 3.0 compared to 300 for a 3.3 as a starting point. Considering the 76-77 is about 10% smaller that is not that much difference per CC. Most often the 3.0 turbos are lighter cars and have better weight distribution. Thus, not that much of a performance potential difference without an intercooler.
To me one of the best things about a 76-77 is the rear wing. It is just a shame to have to remove it so an intercooler can be installed.
I believe you can shoe in a custom intercooler that can fit in the spaces available if needed.
Another approach is to keep the basic car intact and representative of its special status and work to make it run as efficiently as possible without an intercooler. There have been many low boost cars that are very fast.
Cams, headers, low restriction muffler, more efficient turbo (larger compressor wheel), ideal AFR's and ignition can all add to HP and probably get one up to well over 300hp.
On a 3.0 turbo on could pick a cam that moves the efficiency range higher on the RPM curve. Something like an improved Group B cam. The 3.0T has an advantage over a 3.3 in that it has a stronger bottom end and can operate on stock components up to 7300rpm without issue. Moving the peak TQ curve up the rpm curve 10% can add 10% hp.
Another way would be making it bigger. Larger cylinders can get it to 3.2 or more easily. One of my dreams would be to drop a 993 crank in one of these and use a set of Nickie's cylinders and make it a 3.8 (3.75) but leave the outside stock, bump the compression and actually lower the boost. Could end up with 400hp and great low end throttle response.
Twinplugging could help and be something to consider to.
My thought is why add all that extra weight and loose that beautiful tail and special identity. Just polish what you have and make it the best it can be.
Just my two cents.
Old 06-27-2009, 07:40 AM
