how do you remove the fan and housing?
Hi
How do we remove the fan and housing from the motor? I removed the pully and belt . slacked the A/c belt removed the wodruf key but the fan will not clear the rear engine tin .as for the fan housing I have no clue . Thnaks |
Loosen the big metal strap that is under the ignition coil draped over the fan housing... but then again you might have a 996TT for all I know and my response would be considered stupid
![]() What year is your turbo?
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
sorry it is a 930 1989
E-85 sippin drunk
Take the I/C off, then the coil and bracket off (where it bolts to the fan shroud). Then loosen the single bolt that attatches one side of the metal fan shroud strap to the other. Then you will have to undo the air difflector from the back of the alternator, undo the wires, then pull alternator/fan/ shroud out of the car.
In order to get the fan off of the alternator shaft, there are a couple of ways. Here is the way that I do it..... There are around 10 to 12 small holes that are cast into the fan, right around the pulley. Tap two of those holes... one across form the other, 12 and 6 o'clock positions. Then screw in a long bolt, one into each hole. as you alternate screwing both bolts in, the fan will slide right off of the alternator shaft. DO NOT hold the fan by the blades of use anything to block the blades as the will chip / break...and you will have to buy another fan. Its very easy to do.... now, on mine...since I already have the holes tapped, I can take my fan off while its in the car......
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Thanks for your help just did it.
The hole tap idea is sweet Brad, good stuff....
'89 911 M491+Turbo '90 964 C2 '89 944 Turbo '88 928S4 |
E-85 sippin drunk
Thanks... Yea, once the holes are tapped, screw in the long bolts, and they bottom out on the alternator case. Then, as you screw them in more, the bolts will "push" the fan right off of the alternator shaft. I came up with the idea, since I had no puller available.... worked great for me..!!
