best wastegate?
am looking to upgrade my wastegate, stock one is getting a bit tired. Am thinking of
either a tial 46 or pro-gate. Any thoughts as to which is best would be grateful, and which particular model No etc. many thanks Matt... |
Absolutely no complaints with my Teal 46.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
^^^^ +1
Some guys have run wastegates off eBay with success. Long term results, I don't know. |
Tial is the best hands down, no competition that even comes close. The second best that comes in a mile behind is the HKS gates (this is opinion), but I dont even think that they have a product that would bolt in place of the stocker.
The Tial F46 is a great wastegate and if you want to go a little more modern you can use the Tial V44- but you would have to weld a diffrent flange on. The advantages of the V44 is the v-band flange and flows slightly more than the F46.
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
I have always wondered why the stock WG is not the best.
WG’s are binary systems…they either open at the pre-described bar (spring) rating or they don’t. Seriously, am I missing something here? Why would one be better than the other providing they both open at the same bar?
Rod... 2010 - 997 PDK, Black on Black, Daily driver. 1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony! |
I don't think it's an outright upgrade, but if your stock WG need rebuilding, the thought has been to buy a new Tial. At one time I thought it was hard to get new diaphragms, but I think Stephan at IA could get them.
Otheriwse, if it ain't broke, don't fix it. |
If it aint broke dont fix it is right. You will gain no performance at all by changing the waste gate. If your stocker is froze and you want a maintenance free replacement, then get the Tial.
The Tial is far better than the stock as far as longevity is concerned, but for perfromance I am pretty sure the F46 is just a cast stainless version of the stock unit.
The same factory wastegate has been in my 930 for 29 years. I have had it apart several times to change springs, replace broken studs, and to just ck. the general condition internally. Over the years I picked up a couple more used because I thought I might want to use them for spare parts; so far they have been under the bench for 10-15 years. It makes it real hard to justify 400-600 bucks so I can say I have a Tial wastegate that doesn't add a damn thing.
Hell my first wife didn't last that long and was not nearly as faithful. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. |
My stocker decided to leak too much through the valve guide, and through a high-temp (asbestos?) gasket that's sandwiched between the two main components (hard to describe). So I lost my trust in it and bought a used Tial for around $175. Haven't looked back since, but my car is now worth $1000 less because it's no longer stock in the WG arena.
Thanks for all the suggestions, my 930 is pretty much stock with 80,000 miles on the clock so looking to replace turbo, i asked my well known porsche tuner in the uk about rebuilding the waste
gate at he same time, he said it would be worn out and you can't rebuild them. Sounds like he just wanted to sell me a new one! I think i will look into replacing the diaphragm and spring in stock waste gate... |
If your diaphram is fine and the WG is operating correctly, why bother with taking it apart?
Made in Flacht
I've used the stock one in my 92 for 13 years with no trouble. But over the last few months I've bought a couple on ebay which I plan to use for parts. Not to highjack but one of them came with an interesting double spring setup. My stock 92 spring is on the right. Can anyone identify this double spring setup.
1988 944S 2001 Boxster S Seal Grey, M030, PSM 2003 Ford F-350 Dually 6.0 litre Turbo Diesel - You think YOU got torque ![]() 1995 International 9200 Road Tractor 11 Litre Single Axle Daycab Eaton Super 10 Tranny |
I went to the Tial 46 also...but there was really nothing wrong with the original...kept it in order to be able to go back to stock if someone wanted a totally stock car. Tial is generally recognized as the leader in the industry for an upgrade.
1987 factory Slantnosed 930 Cabriolet/Guard's red 2002 Midnight Blue 996TT X50 1999 Iris Blue 996 (Dash fire burned and totalled 9/07) |
Crotchety Old Bastard
What? You wouldn't put this $100 Asian crap on your $25,000 engine?
Take a look at this ricer garbage. I bought one to compare to stock and TiAL. (The TiAL is Black, I think it was yours Chuck). The Asian WG weighed nothing and was made out of pot metal and plastic. TiAL is artwork in stainless. The only drawback to the stock wastegate is the weight. That thing is heavy. Below also is a picture of the stock waste gate disected. Not much to it. ![]() ![]() ![]() ![]()
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Looks like someone was trying some aftermarket springs, as the Tial can use two springs to acheive certain PSI's.
Are there any color markings on the springs? Quote:
Made in Flacht
A930Rocket. my eyes are getting old but I couldn't find a stamping or etching or a color code dot on either of them. The only clue is the length at 6" and the color which is a metallic bronze. But a helper spring for a boost spring sounds cool. I'll keep them both in my parts bin and break down the wastegate for parts to keep my factory one running
