FUSHIGI
964 Turbo (965) rear suspension conversion to RSR 3.8 specs.?
I've searched but came up with nothing.
Has anyone compiled a comprehensive list of parts and/or mods needed to convert the rear suspension of a 964 turbo into the deep offset 964 3.8 RSR rear (assuming this is possible)? Thanks in advance.
Old 08-08-2009, 06:38 PM
The 91-94 turbos because of how there arms are constructed make it difficult to fit wide tires on the back.
From what I understand, the RSR used a special set of arms that were basically
C2 normal arms with solid or stiffer bushings. This made room for 12" (?) rear rims.
Old 08-08-2009, 09:08 PM
FUSHIGI
That is my understanding (installing n/a carerra trailing arms) as well. However, it seems to me that there would be brake, axle length, swaybar width and wheel offset (anything else?) concerns as well. I'm trying to get a handle on what it would take to do such a thing.
Old 08-09-2009, 03:32 AM
Metal Guru
911nut's Avatar
Do a search on Rennlist. There are lots of threads on this subject over there.
I believe that all you need are the C2 control arms, C2 half shafts and C2 sway bar.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 08-09-2009, 03:59 AM
930gt-40r's Avatar
Ask Hood- he has a nasty set up involving the C2 arms with deep dished 3.6 turbo rims
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 08-09-2009, 06:43 AM
FUSHIGI
I'm sorry but I'm not seeing a user name "hood"
Old 08-10-2009, 05:49 PM
930gt-40r's Avatar
Oh no no no- His screen name is Strokher Racing I am pretty sure
Kris @ Tech9
86' 930/GT-40R Sold
Old 08-10-2009, 09:12 PM
onboost's Avatar
Check with Bill Verburg..
- he has quite a bit of insight into the differences and nuances of the 964 suspension..
RGruppe #180
Old 08-11-2009, 09:28 AM
If you do the N/A trailing arms and want the deep lips let me know as I am building for a fellow Rennlister 10 & 12 x 18 Speedline rims for his TT GT2.
Jim
Old 08-11-2009, 11:17 AM
onboost's Avatar
Jim..
Still looking forward to working with you on the couple of sets we talked about.. you know how this stuff goes though.. on again.. off again or chicken before the egg?
Paul
RGruppe #180
Old 08-11-2009, 11:30 AM
Speedline wheels
I am around - tomorrow I get to start a restoration on a set of Ferrari F40 Speedline wheels. They are 13 x 17 in the rear and should be a treat to restore. 805-498-7261
Jim
Old 08-11-2009, 11:51 AM
