-   -   Jacob's rebuild thread (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/492267-jacobs-rebuild-thread.html)
A930Rocket 01-01-2010 02:02 PM
Jacob
Maybe I missed it but why did you replace the intermediate shaft gears? I hadn't anyone doing that I recall.
Jim
Vin-barrett 01-01-2010 02:20 PM
Originally Posted by jwasbury (Post 5100754)
Well...fellow pelican Vinny helped drop the engine (and hopefully will help putting it back in)
no worries, i'll be there =)
jwasbury 01-01-2010 02:21 PM
Originally Posted by A930Rocket (Post 5100804)
Jacob
Jim
They were showing some wear. Perhaps they could be reused, but the new sprockets are not much $ in the grand scheme. I don't like the idea of new chains on old sprockets either. This was a "better safe than sorry" thing.
jwasbury 01-03-2010 03:48 PM
'nuff said
http://asbury.smugmug.com/By-Land/Po...8_NFtEN-XL.jpg
jwasbury 01-30-2010 02:09 PM
Hello Gents
Putting the topend together and I have some questions about the cylinder cooling tins. For those who have been down this road, please have a look at the thread I started over on the engine rebuilding forum:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/524074-cylinder-cooling-tins-can-i-get-ruling.html#post5156206
Gratuitous rebuild pics:
http://asbury.smugmug.com/By-Land/Po...45_xM3k9-L.jpg
http://asbury.smugmug.com/By-Land/Po...80_BhDuL-L.jpg
http://asbury.smugmug.com/By-Land/Po...21_jpAyS-L.jpg
jwasbury 02-14-2010 05:58 PM
Happy Valentine's Day dear!
Update...I bought a set of used 3.2 cylinder cooling tins to use instead of the originals. IMO this is necessary with the upgrade to fully finned cylinders. Too bad I didn't know in advance or I wouldn't have had my originals powder coated.
Yesterday I primed and painted the tins. I also spent a fair amount of time making sure that the cylinder height was even. Checking with a straight edge accross the deck, at first it appeared that one was short. I pulled the jugs up enough to put a vernier on them, measured multiple times and found them equal. Still with a straight edge one seemed lower. This was not making sense, so I bolted the heads on and put some torque on the nuts. Then I put my straight edge across the head to cam tower mating surface and everything looked perfectly even...good! The base shims must have been pushing the jugs up ever so slightly and making it look as if the cylinders were uneven.
Today I made some good progress got the top-end bolted up...
Camshaft housing and heads clean and ready on the bench
http://asbury.smugmug.com/By-Land/Po...7_wCKMs-XL.jpg
Left bank completed
http://asbury.smugmug.com/By-Land/Po...5_uEapd-XL.jpg
Right bank going together
http://asbury.smugmug.com/By-Land/Po...5_MVX2i-XL.jpg
looking like a flat six again
http://asbury.smugmug.com/By-Land/Po...5_oQZPb-XL.jpg
here's her bottom
http://asbury.smugmug.com/By-Land/Po...4_sPg6u-XL.jpg
pkracer21j 02-14-2010 06:21 PM
Lookin like a million bucks Jacob! can't wait to see what kind of numbers she lays down!
juicersr 02-15-2010 04:52 AM
Sweet Jacob! In the words of Borat, Veeerrrryyy Niiiiiice!
You are kinda on the 'home stretch' at this point.
BTW, just curious as to why you went with ARP head bolts vs Supertec?
jwasbury 02-15-2010 07:41 AM
Geeze...that sure is a loaded question around these parts. Lot's of people seem to have success with either from what I have gathered in my research.
ARPs are recommended by LN Engineering for use with Nickies cylinders on their website, although I've seen that Charles Navarro has also endorsed Supertec's stud here in the Pelican forums. I bought the P&Cs through Chris Carrol at Turbokraft who uses and recommends the Nickies cylinders. He also recommended the ARP hardware, so it was convenient for me to do everything in a single transaction.
jwasbury 03-07-2010 07:13 PM
Bit by bit, putting it together. It was over 50 degrees today. Getting antsy to drive...
http://asbury.smugmug.com/By-Land/Po...3_Wbu79-XL.jpg
Turboo934 03-07-2010 11:50 PM
Looking good Kid.
TurboKraft 03-24-2010 09:24 AM
Jacob -- great work on the engine, and great photos.
jwasbury 03-24-2010 01:08 PM
meanwhile, back at the chassis...
...Been working on wiring up the new ignition system--->
Coil packs mounted and hooked up with wire harness
http://asbury.smugmug.com/By-Land/Po...9_SqS8D-XL.jpg
Harness follows the A/C line and then through a new hole I bored in the firewall
http://asbury.smugmug.com/By-Land/Po...9_SZ9gm-XL.jpg
Inside the car...electronics are mounted underneath the passenger seat. That's the Electromotive ignition brain, and an Innovate DL-32 datalogger. The datalogger will hook up with my LC-1 wideband AFR, and I will be logging RPM, Boost, AFR, and CHT, plus it has a dual axis accelerometer.
http://asbury.smugmug.com/By-Land/Po...2_3xLpL-XL.jpg
And finally at last the obligatory pic of me in the engine bay. If I look pissed off, its because I just spent the last 5 hours hunched over pulling wires, stripping insulation, soldering, etc in a 1 car garage with no electricity and no access to running water. My back is PISSED.
http://asbury.smugmug.com/By-Land/Po...2_pSkbf-XL.jpg
Vin-barrett 03-24-2010 01:16 PM
smile jacob, your almost there
juicersr 03-24-2010 02:07 PM
All part of the journey grasshopper.;) Just keep thinking about how awesome all that new horsepower is gonna feel come summer. Besides, what else would u be doing, chores around the house or something equally useless???:D
krasuskyp 03-24-2010 04:37 PM
saaweeeeeeeeeetaaaaaaaaaaaahhhhh on the DL-32! Schwing!
ditto for der rest 8-)
stay focused - be the ball, Danny... fa na na na na naaaaaaaaaaa
9dreizig 03-24-2010 07:08 PM
Very cool Jacob!!! That beast will be ready for the next Turbopalooza!!
A930Rocket 03-24-2010 07:28 PM
Great updates! It'll be ready for spring.
MikeD930 03-25-2010 04:21 AM
The end is near, Jacob, hang in there! Good job on your project.
krasuskyp 03-25-2010 04:47 AM
http://swarthmoreasianorganization.f...009/08/end.jpg
