beancounter
Jacob's rebuild thread
And so it begins...
Engine is on the ground. Teardown will commence in the next couple weeks. ![]() ![]() Leakdown was 44% on cylinder 6, as I mention in this thread: Leakdown test reveals ugly truth The engine has about 60k miles on it. Goals: To build a reliable street engine, with a little extra performance over stock, upgrades that are complementary to the mods I already have: K27S, Turbo SSI heat exchanger system by Rarly L8, Rarly L8 muffler, Kokeln intercooler with full 965 intake. Current plans are: Take it down to the crank. 3.4 LN Engineering Nickies cylinders and JE pistons (7.5/1 compression ratio) Heads reconditioned and mild porting (probably to 36mm) Do the twin plug machine work (to allow for easy future ignition upgrade, just in case) Might as well do the cams (probably SC) New headstuds ARP rod bolts LN Engineering offers slip fit 100mm P&Cs which will yield a true 3.5 liter. I am considering this route. Opinions and suggestions welcome I'll update this thread as I make progress. cheers!
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
beancounter
Special thanks to Pelican Vinny (screen name Vin-barrett), who worked with me today on my virgin engine drop. You are the man!
Congrats! Who is going to do your rebuild?
Yasin
Ole Skool - wouldn't have it any other way |
Blackbird Pilot
Awesome Jacob -
glad to see it going in for a bit more pep and a 3.4 will not disappoint! hope it goes well
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us |
beancounter
I'm doing it with the help of this forum, Wayne's book, and a few wrenching buddies.
very cool
subscribed to the thread
-Vinny 1983 911SC |
Crotchety Old Bastard
If you enlarge the exhaust ports or swap heads that have larger ports you should cone the gasket protectors on the SSI exchangers to match. The ID of the pipes will allow for velocity without choking with the cone transition. This will retain good off-boost torque for driveability as well. I would not swap out turbos until you are finished and see the results. If the desire is low boost street torque monster you may be just fine as is.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
beancounter
Turbo Hooligan
ohhhhhhh subscribed bro! I didn't think you'd get started on her this early. I thought it was going to be more of a winter project. If you don't plan on turning up the boost, I'd go for the 3.5. no replacement for displacement.
btw, are you going to strip out your A/C or try and recharge it?
D-Zug ![]() |
Subscribed!!! ,, Make sure you document the$$$ too we'd like to see that
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Champagne on Beer Budget
Sub'd... Headed down this road too!
Einar www.einarsgarage.com Instagram @einars_garage https://www.facebook.com/pages/Einars-Garage/375533809160797 |
beancounter
Wayah Road Warrior
Where are the pics!
C'mon man ... this is the Turbo board ... we need pics of EVERY step along the way. Start with the opening of the 1st beer bottle, then the hookers ... oh ... I mean yeah ... engine drop pics. And DO NOT FORGET the obligatory Jacob in the engine(less) bay pic.
02 996tt White 87 930 GP White (Sold) 87 911 Targa Guards Red(Sold) Last edited by Shadetree930; 08-18-2009 at 10:12 AM.. |
beancounter
Some progess and some pictures
My engine sat on the atv jack for about two weeks after the drop...life got in the way plus there was a little logistical issue that required completion prior to tear down ----> I had to transport the engine from my rented garage (a few miles from my home) to my home garage. The engine move was completed this weekend, and tonight I got to make some progress on the teardown. I removed the engine tin and pulled the manifold and the entire CIS as an assembly.
Engine in the stand prior to tonight's work: CIS injectors "pickled" in seafoam: ![]() Manifold and CIS induction removed: ![]() I noted that every one of the plastic CIS injector blocks had some amount of cracking. Nothing was visible from the outside, but each had a crack propagating from the inside on the cylinder head side. Cylinder #5 was the worst and there was actually oil underneath the injector block. ![]() remember that I had 44% leakdown on #6, so I was getting a lot of blowby. Crankcase pressure was pushing a lot of oil into the intake. I think that the cracked injector block on #5 was leaking and allowed the oil to seep out. In the past I noted that the threads on #5 spark plug were oily...now I know why. More to come...
Great work Jake. Taking apart your motor is a fascinating journey into it's inner workings and a truly great learning experience.
Keep the pix coming.
DZ12,935K3,934,2.8RSR Ducati 900ss/GhezziBrian STW dzugautomobili.com |
PS - Is that your Duc in the corner? Mandatory pix of her without the cover at some point in this thread.
Jake..
Looks like you're making great progress.. better than me the last few weeks! Good luck and enjoy the journey. Paul
RGruppe #180 So many cars.. so little time!! |
Turbo Hooligan
Keep the pics coming Jake, and I 2nd the mandatory pics of the Duc!
D-Zug ![]() |
no matter how many rebuild threads I see, I enjoy reading another, subscribed, great stuff!!
'89 911 M491+Turbo '90 964 C2 '89 944 Turbo '88 928S4 |
Subscribed as well. I would love to tackle something like this someday.
1998 993 C2S Guards Red/Black 1990 964 C2 RWB project car 2016 GT3RS White Daily driver 2018 Lamborghini Performante Gegio Telesto |
