e p slick's Avatar
7200 rebuilder recommendations?
My 7200 is getting pretty wet and most likely needs seals/freshen up.
Anyone out there recommend who might be a good choice to do the job?
EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 09-08-2009, 05:17 PM
A930Rocket's Avatar
Kevin at UMW did mine, but I'm sure others are out there.
Old 09-08-2009, 05:31 PM
Ingenieur
You are a great choice! DYI, if the wheels have not rubbed. You can do it!
Old 09-08-2009, 06:31 PM
Banned
Here is a shop that another board member (Jfairman) has recently used and was pleased with:
http://www.durabilt-turbo.com/
Old 09-08-2009, 06:35 PM
e p slick's Avatar
Ok
Have nylatroned a lot of blower rotors and replaced seals but never fooled with a turbocharger. Guess the process must pretty much be the same. Is a press used to get it apart and back togerther? Any suggestuion on where to get seals? Any tips that might help me not screw it up?
EPS
Old 09-08-2009, 07:05 PM
lite75's Avatar
+1 on DYI, if there isn't any damage to the main components it's easy to replace the seals. Make sure to mark the compressor wheel and turbine wheel so they can be lined back up when reassembled. Kits can be found for about $50.
75 930, 76 930, 83 SC EFI turbo
Old 09-08-2009, 07:16 PM
e p slick's Avatar
Ok
Ok
EPS
Old 09-08-2009, 07:29 PM
