-   -   Ultimate 930 Distributor, advance, retard, timing, Turbo lag, MSD, mod, thread. (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/500986-ultimate-930-distributor-advance-retard-timing-turbo-lag-msd-mod-thread.html)
mark houghton 01-06-2010 09:29 AM
Good description, Jim. I used Weber DGV32/36 downdraft carbs on my old MG's....I can relate. Just need to take a very close look at the 930 throttle body relative to where the ports are to fully understand.
911st 01-06-2010 09:41 AM
Break through!
Mark,
Welcome. Very nice car.
I find your post very exciting!
Your timing numbers are much more ideal than the US numbers we have been working with.
We see about 10 deg with vac or boost retard and 18 deg mechanical.
You see more like -14 with vac or boost and 12 mechanical.
This gives you a greater jump in advance off idle, allows you to run more advance at cruse for greater efficiency, and still pull back a significant amount on boost .
A better set up for sure.
To me this info is HUGE!
Several times I have stated I think a way to improve our systems is to increase the range of Retard available to us. I believe this can be done by modifying the stop behind the pot that limits the total retard we can get.
Mechanical Advance can then adjusted to fit the ideal on boost goal.
If you car is doing so, it is proof it is achievable.
Here is how the combinations might compare--
Using stock US values adjusting idle to TDC.
TDC at idle,
-10 on first accel
-18 on boost
-28 cruse
Your Euro car w idle set at TDC:
TDC at idle,
-14 with first acceleration,
-12 on boost
-26 on cruse.
Using US mechanical w euro advance/retard:
TDC at idle,
-15 on first accel
-18 on boost
-33 on cruse
Of course you can move all these values up or down by where the timing is set at idle.
If we do this with the Euro to get the on boot to -18 it would look like this:
-6 at idle
-20 with first accel
-18 on boost
-32 in cruse.
This might give a lot better off idle pull, safe on boost, and better fuel economy on cruse.
Ya! I love it!
The best!!! ;)
JFairman 01-06-2010 09:53 AM
Weber 32/36DGV dual choke downdraft carbs were also the carb of choice on BMW's when keeping the origonal intake manifold and replacing the origonal worn out 2bbl downdraft Solex on 1974 and later 2002's, and the dual 2 bbl carbs on the BMW 2800, Bavaria, and 3.0CS.
Crazy people like me put in 10:1 mahle pistons, 300 degree duration BMW motorsport or Shrick cams, Stahl tuned headers, and dual sidedraft Weber 45 DCOE carbs with 38mm venturi's while hogging out the intake ports to around 44mm after looking at and studying alot of pics of Jim Rowe's BMW M10/M30 engine intake porting theory in his Metric Mechanic book.
911st 01-06-2010 11:39 AM
Ignition Retard, CIS, Lean surge, resident boost?
Another light bulb might be going off.
Carbs and EFI have a method to deal with the lean surge that comes with acceleration by increasing fuel flow. 3.3 930's do not. (stock 3.0 930's do.)
If we run significantly retarded timing as Porsche specs at idle, the adjustment at the air bypass screw must be opened to keep the idle on target.
This increase in air and fuel then lies in wait for timing to create acceleration by just quickly advancing the timing.
With retarded timing exhaust temps go up as the fuel is still burning when the exhaust valve begins to open. Thus, less energy it imparted on the piston and more on the turbine. This should increase our resident boost. (I used to have about .2 bar off idle.)
We have found that more advance increase pre-boost response. Could it be we want to keep our timing retard at idle and concentrate jumping advance more off idle.
If so, for those going to a programmable MSD, you might try keeping idle timing close to stock spec and then get aggressive with timing advance with acceleration.
JFairman 01-06-2010 12:03 PM
In real life use just removing the red vacuum retard line from the distributor advances timing around 10 degrees at idle and makes these cars alot peppier at city driving speeds without boost so I don't promote the stock retarded ignition timing at idle.
There's no use for it other than the higher exhaust temps it causes at idle to help heat up the catalytic conveter and lower exhaust emissions.
The 1987 930 owners manual even warns against letting these cars idle a long time while adjusting the idle CO because it overheats the intake ports from heat transfer from the exhaust ports and there is less cooling airflow from the fan. FWIW, apparently letting the cylinder head ports overheat will make it difficult to properly set the idle CO accurately.
I've never heard anyone besides you talk about off this "off idle lean surge".
I don't have an off idle lean surge with the modified fuel head in my car and I don't think my buddies '87 930 with a stock USA fuel head does either. We both have the Innovate LC-1 controller and analog AFR gauge to see whats happening.
The 930 CIS takes a second to react to throttle changes with the low airflow going through it just off idle but from my experiences it's not a "lean surge".
911st 01-06-2010 01:26 PM
J,
If just removing the Vac-Retard connection (not removing and resetting timing) to the pot makes the car snapper then the power of more ideal advance overrides which is something I was wondering about. I do not like the idea of making any more heat than necessary.
I do not know if 'lean surge" is an accurate term to describe my observation.
It is not so bad the car coughs.
On my 3.3 C2T with euro fuel distribution head I used a stand alone Motec wide band when setting up my controller driven Andial-Fueler frequency-valve to dial in my AFR's at all points off WOT. (WOT was done on a load dyno.)
With aggressive throttle application I noticed my AFR did lean at first. If I was set in the mid 14's at idle -- I would see a jump into the 15's briefly with aggressive acceleration.
I am surprised if this is not evedent to others running Wide Bands.
If that is the case, I guess I could have had an issue others do not ( such as binding in the metering plate, thought I had it apart to blue print the metering pin travel and noted nothing).
Another possibility might be the Motec unit was more sensitive to change. I know the O2 sensor was Mote supplied and new. Maybe there could be some level of soothing difference between the two instruments to make them more readable.
I believe most of the sluggishness of CIS comes from the metering plate restriction and mass. Many CIS cars add enrichment (reduced control pressure) with loss of vac including VW, Audi, and Porsche. I was told the 3.0T did, 3.3's do not.
My biggest single improvement to throttle response off idle was aggressively lowering control pressure with acceleration for a brief period.
I am surprised no one else sees some leanness at first with aggressive acceleration.
JFairman 01-06-2010 01:56 PM
Wideband AFR gauge kits have gotten better over recent years so if anything the new ones are more accurate than the Motec you used when you had a turbo. I think you've said that was around 6 years ago?
My friends car and my car are both USA 1987 models and both have 964 cams. His car has a stock USA fuel head and both cars have a K27 7006 turbo and halfbay Garretson intercooler.
Both of our cars idle alot smoother and faster with the AFR hovering around 13.8:1instead of 14.7:1 when fully warmed up and thats where we have them set.
Maybe thats why we don't go lean into the 15's when first giving it the gas.
My steady cruise AFR is around 14.7:1 at around 2000-2500 rpm and then it hovers around 14.5:1 at 3000rpm in 4th gear or 80mph on flat Florida roads.
mark houghton 01-06-2010 02:19 PM
I don't see the leaness, Keith. If it's there at all, I'm talking a scant 1/10's or 2/10's AFR for a half-second while the metering plate moves, but not noticeable from a seat of the pants performance standpoint.
If we really wanted to test it, and since I still have my old Andial fuel enrichment gizzmo plumbed in, I could trigger it at will from the cockpit...say within the first second of touching the throttle, and force a rich condition. Or as I threatened to do before, put a window switch in to activate the Andial at 1200 rpms and turn it off at 2500 or some arbitrary point like that. The problem with all that is too many gizzmos hanging around the engine bay, doing what a nice programmable controller could do (such as you once did, and as Thierry has done, with the AIC).
911st 01-06-2010 02:23 PM
JF,
I have suspected setting the CO at 3% was to improve off idle TQ.
Do the LC's have a sensitivity setting?
Anyway, when I got done with my set up I idled at about 14.5 and with accel would jump to about 12.5. Again, I lowered CP to under 1.9 bar for a brief time with acceleration and did not know about 13.2 was a more powerfull setting.
Same thing on cruse. About 14.5 and instantly to 12.5 then to 12.2 on boost per the advice of my tuner at the time (he was an import turbo guy). I told him I wanted to be in the 11's on boost but he talked me out of it. I think I ended up at just under 13/1 at read line at .92 bar (K27-7200) where I was running out of fuel and could get no more air out of the turbo.
flatsix777 01-06-2010 02:38 PM
I think stock CIS provides acceleration enrichment through overswing of the sensor plate as you initially jump on the gas. This momentarily takes it past the full throttle open position. This is set out in the Bosch Technical Instruction for K-Jet (probably shouldn't post the extract).
On my logging I can't find an instance where AFRs go lean as the throttle is aggressively openned in gear. AFR's seem to drop in direct relation to RPM climbing at WOT. Perhaps it's not sufficiently granular but you can't see it on the trace.
JFairman 01-06-2010 02:57 PM
There is no sensitivity setting on the innovate lc-1. It's a weather sealed unit.
To fully calibrate the lc-1 the first time or if it has become corrupted you have to clear it's memory by turning it on for 20 seconds without the o2 sensor connected and then turn it off.
Then you connect the o2 sensor in free air with no exhaust fumes around it and turn it on for 2 minutes to calibrate the lc-1 to the o2 sensor and it's heater element.
Then turn it off for at least 30 seconds before starting the car with it installed in the exhaust pipe.
They say you should do a free air sensor calibration once a month on a turbo car, and before every track session in a track car.
You don't have to do the memory clearing step every time if it is working correctly only the free air calibration and a little red button and red LED come with it for free air calibration.
You don't have to remove it from the exhaust to do that either, just wait overnight and do it before starting the car once a month or whatever.
You can update the firmware on it with a laptop if needed but thats more involved.
911st 01-06-2010 03:49 PM
Got it, the LC's can be calibrated but there is not adjustment for, shall we call it, refresh rate or soothing.
Maybe this is not even a function of O2 monitors as they do not react to changes in AFR's fast enough to need such a feature.
It seems the way CIS is designed it is much more sensitive to air flow changes off idle and cruse. This is part of how it deals with potential for lean-onset, shall we call it.
Some of the WUR are vacuum sensing so when vac is reduced with acceleration the reduce control pressure some to richen the AFR for acceleration for what it is worth.
Seems getting our AFR's to about 13.2/1 pre boost (max TQ setting) and the timing advance right is going to be our best goals.
911st 01-07-2010 03:36 PM
Found some old info from from a very good source on Rennlist back in 2001 when I was setting up my programmable CIS Fueler and was looking into what my AFR's should look like that might be a couple of interesting timing data points:
Here is what I've done with my MoTec M48 in my 930. 7.2:1 real compression, variation of 964 cams, 3.2 carrera manifold.
At idle, you'll want enough fuel to allow the car to idle smooth and that will vary with each engine configuration. Mine engine likes about a 14.0:1 AFR to idle properly with an ignition timing value of 7 degrees BTDC. At sites below your target idle you may want to increase the timing and increase some fuel. This will help get a solid idle. When the engine drops below your target idle, the additional timing in those sites will tend raise the RPM back to idle.
You may find that at sites just off idle you need quite a bit of fuel due to dropout (fuel sticking to runners, etc because of slow air velocities) and this will decrease by about 2250rpm.
As far as cruise goes. You'll need to find out how much pressure your car makes at idle. With my cams, my car idles at 56kpa, so my cruise comes at 70kpa or so. Here, the cylinder filling is inefficient and it is almost impossible to detonate the car. You can run a very lean mixture and significantly advanced timing. This will help your torque and you will have much better drivability and better throttle response. I run about 14.5:1 and about 37-38 degrees of timing. note: a 993TT under cruise may run as lean as 15:1 and 44 degrees of timing. You can test this by driving the car at cruise and decreasing the fuel until the car starts missing, here it is too lean so add some fuel.
At about 80kpa, I start decreasing my AFR so at 100kpa I run about 12.8:1 AFR and about 32 degrees of timing. I start pulling timing fairly quickly and increaseing the fuel as the pressure increases and run about 26 degrees of timing under full boost - 200kpa (1bar) except where my torque is peaked and there I run 24 degrees of timing. I aim for a 12.2-12.5afr.
Two words of advice, use a wide band AFR to tune, and use a dyno to get a baseline. You can adjust your cruise while driving because it is hard to do any damage while the cylinder has inefficient fueling.
What EFI system are you running?
Racetek Engineering
93 C2/RSR 3.8
92 C2 Coupe
89 911 Turbo
91 944S2 Club Sport
87 924S
Geoffrey is offline Reply With Quote
Geoffrey
View Public Profile
Find More Posts by Geoffrey
Old 04-13-2003, 04:07 PM #4
Geoffrey
Addict
Rennlist Member
Geoffrey's Avatar
Send a message via AIM to Geoffrey
Post
Oh yea, if you run an overly rich mixture 11.2:1 you will cause so much heat in the turbo that it will significantly shorten its lifespan. Also, you may have a secondary ignition in the turbo = bad!
911st 03-31-2010 08:15 AM
mark houghton 03-31-2010 09:02 AM
My favorite topic!!!
He said: "I run about 14.5:1 and about 37-38 degrees of timing". and he said "...run about 26 degrees of timing under full boost - 200kpa (1bar) except where my torque is peaked and there I run 24 degrees of timing. I aim for a 12.2-12.5afr".
I know that information is specific to an EFI car. Personally with CIS, I run about 38 degrees advanced at 4000 rpm's no-boost/14.2:1 AFR, and about 16 degrees/11.8-12.0 AFR on full boost. Safe with neighborhood generic 93 octane gas. Interesting to see where additional timing can be had without ill effects, though I don't think I have the balls to go with that much on boost with the relatively crude CIS.
911st 04-28-2010 07:41 AM
Some great data points from a real expet I thought would be good to referance here:
Originally Posted by RClewett (Post 5321028)
911st,
The CIS system does/did a great job for what it was designed to do. It met emission standards and had reasonable performance. The CIS system does have its limits. The biggest problem is that after 20+ years mechanical parts wear out, and good 930 fuel distributors are hard to find. Good modified fuel distributors are even harder to find. With modified fuel distributors, low speed mixture control can be difficult to keep from fowling plugs. Warm up regulators are also a contributor to this problem. When you add the performance minded individual into the equation, the mixtures are adjusted richer than originally designed; and with no way to adjust the fuel range of fuel delivery, problems can arise.
For the rich idle condition at low speed, it's not so much how long is the spark or how many sparks you have. But do you have enough heat in the chamber to burn the fuel? When the mixture is too rich, there's not enough heat to burn the carbon off the spark plugs, and they foul. To maintain enough heat in the chamber, the mixture shouldn't be richer than about 13:1 AFR at idle, hot.
In my opinion, the fix for CIS is to go EFI. I admit, I'm spoiled. It brings the engine up to modern day ignition and fuel control technology. It is very easy to make changes and provides the means to use a wide variety of performance components. With EFI, much of the CIS and turbo lag can easily be tuned out, making the engine much crisper. By adding some slightly more aggressive cams, a 930 will wake up and start making some real power. That's why I'm spoiled with EFI.
Twin plugging might help the off idle response some. But the real fix is to have the correct mixture and timing.
With timing, the goal is to have peak cylinder pressure at 14 degrees ATDC. Earlier than 14 degrees develops excessive heat and beats up the top end of the engine. Later than 14 degrees leaves power on the table. The dyno is the best way to find the sweet spot. I typically recommend for a single plug 930, 20 degrees at .8 boost. On the dyno, I've been everywhere from 18-23 degrees, so I pick 20 as a happy medium and starting point.
The timing at .8 and 1 bar are about the same, maybe 1 degree less at 1 bar.
Twin plug is usually about 2 degrees less than a single plug timing. This number also depends on RPM. With EFI I'll add a couple of degrees @3000 and back timing down a couple degrees by 7000. There is certainly a power difference between single plug and dual plug engines.
I hope this helps,
Richard
911st 04-28-2010 07:43 AM
Here is where it cam from: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/537769-replacing-distributor-2.html
cole930 04-28-2010 01:47 PM
I appreciate Richards input. If I had the money he charges for his parts I could go to EFI.
Cole
John at J&S 04-28-2010 02:57 PM
Let the street be your dyno and let the SafeGuard adapt timing in each cylinder to the conditions on that day.
drmatera 04-28-2010 03:49 PM
john at J&S - is there some tuning needed to get the safegaurd working right? I thought the air cooled motors were so noisy that knock detection was difficult
