Ultimate 930 Distributor, advance, retard, timing, Turbo lag, MSD, mod, thread.
How can we improve a 930's ignition?
I suspect there is a solid improvement to be made in off idle response, spool time, and fuel economy. To see the potential of a more ideal timing, just pull the vacuum line off the inside connection to the vacuum-boost-retard-can on the distributor at idle. This will advance timing about 9 deg. Idle will increase about 300 RPM because the ignition will be closer at a more ideal setting. With this it will make more power with the same amount of air and fuel. Timing is ideal if combustion pressure reaches its max at about 12-14 After Top Dead Center on most motors. I have reviewed many of the threads on timing and it looks like there seems to be some general misunderstanding on how our system works and a fair amount of miss-information. Further, most do not seem to know what a more ideal timing curve might look like. Together, lets fix this. There also seems to be very few solid suggestions on how to make improvements in if there are they have gottin lost among all the clutter. Some even believe that some of the 930 tuners have figured out how to make improvements but are not talking. When the 930 was built Porsche seems to have made many design accommodations in the name of emissions. They shaved most the cooling fins off the cylinders to get the motor to run hotter, they put a cat on it, they added an air pump, they put small intake ports and funny tops on the pistons to get a better air/fuel mixing and who knows what else. They also seem to have made compromises with the ignition by adding a Vacuum-Retard function whose prime function is reported to increase heat in the motor for emissions. This appears to be at the expense of low rpm throttle response. Of course the best way to achieve ideal timing would be to change to a fully programmable system and abandon the weights & springs with vac/boost-retard can. Porsche did this with the C2 turbo. I am thinking one possibility for a best practices set up would be based on the newest fully programmable MSD with a locked distributor. However, I suspect significant improvement can be made with the stock set up by re-curving the distributor and shortening the mechanical advance to increase the advance off idle. |
So what is our timing like and what would a more ideal look like?
For a stock US 930 I believe our timing looks approximately like this. +1 (1 deg ATDC) at idle (quickly jumping to apx -8 with acceleration), -26 (26 deg BTDC) at cruse above 3000rpm, -16 to -17 on boost. This comes from a combination of the following: -Vacuum-Retard of about 9 deg. When this goes away with acceleration and effectively advances timing. There is no vac-advance on 3.3 Turbos. In general I belive vac-advance is to increase economy and vac-retard it to benefit emissions. -Mechanical Advance of about 18 deg that is full in by about 3000rpm. -Boost-Retard of about 9 deg. that is full in by about 5 psi. What would a more ideal timing look like”? I would love to see more input on this but one EFI turbo ignition timing table reviewed leads me to think it might look more like the following: -15 (or more) at idle (w aggressive advance by 2500rpm) -35 on cruse (seen reference up to -42 w little load) -16 on boost Our net on-boost timing seems good. We come up short with on cruse timing. However, cruse timing dose not seem hurt our performance to a significant deg. It dose however cost us, by one report, about 5% in fuel economy. Our best and most usable opportunity seems to be to improve idle and pre-boost acceleration. More low-end could also mean earlier boost onset. Further, our boost-retard seems to be all in with about 5 lbs of boost. Bringing this in, in a more progressive manner might reduce spool time. Thus, we can do better! |
First however, it might be worth testing to see if it is worth the effort. I am thinking we should test the low-end opportunity from more advance and the on boost opportunity to find our truly what our timing goals should be.
Testing low end timing advance. This can be done as simply as resetting idle timing advance from the stock +1 (1 deg ATDC) with a timing light and going out and doing some acceleration runs up to 2500rpm. Do not go into boost much as you may not have enough boost retard protection. I suspect we could bump timing to about -6 to 9 deg at idle and feel the difference. I would like to suggest that we also test eliminating the Vac-Retard function that comes from the fitting on the can at the distributor and closest to / facing it. Some of my reading indicated that vac-ret was added to cars to make them run hotter at idle for emmissions. When this is done idle will increase about 300rpm because timing is set to a more ideal level. If we try this we would just re-adjust the Air Bypass screw to reset idle. Timing will jump to about -8 deg at idle from this alone. Try adjusting for more advance and idle should increase further. Again if the idle increases is an indication that timing is at a more ideal point for the amount of load and AFR at that time. However, under load we can not take as much advance as when not under load. If we go to far the car will balk and tell us. Most likely we will get to the end of the adjustment range available at the distributor before we reach the best advance for acceleration. I suspect about -15 is going to be a good place to be. Of course a better test would be to find a dyno and a good tuner to supervise and do runs from 1000rpm to 2500 or a load type dyno so load can be set at say 1500rpm and then advance timing from stock a little at a time and then backed off a little once the most power is found. Testing Full Power timing under Boost Retard: This is more involved and best requires a dyno and the supervision of a good tuner. I am thinking we would start by setting timing per factory procedure but at a lower setting to something like -22. I suspect we should use tune for max power at “Torque Peak” instead of HP Peak as or point of reference. My reasoning is at TQ peak we are most sensitive to detonation (running rich at TQ peak could be an advantage). I would verify AFR’s to be no leaner than 11.5 (or what ever your tolerance for risk and beliefs dictate). From there after, try advancing timing some and retest until TQ is maxed and back off a little for safety. This should give us an indication of our ideal timing given our build and the type of fuel we are running. We will probably not know our actual timing goal under load unless we sit on the timing light when on the dyno. We will have to back into it. Until then I suspect we want to be at about -15 to -18 at full boost. |
How do we improve the existing 930’s ignition.
I am thinking the following methods might be worth considering. MSD, fully programmable: MSD-6AL-2 Ignition Control - 6421 I suspect can we not only get more ideal timing using a programmable ignition system, MSD offers a unique advantage in that at low rpm its higher intensity and ability to generate multiple sparks will be more effective at burning a lean air-fuel mix that is typical with a boost-enrichment WUR that dose not have acceleration enrichment capability. This is one of the prim advantages of twin-plugging a CIS Turbo. Thus, it would be a double win! Because of emissions goals and limitations of using a “weights & springs” mechanical advance with a vacuum canister, we should be able to make improvements in the following areas. Of idle: We are at about +1 deg at idle jumping to about -8 off idle when we blip the throttle. I suspect we should be closer to -15 at idle and to about -22 by 1500rpm. This should increase throttle response off idle, get us to boost onset faster, and even lower the boost onset point. It will also make for a cooler running motor at idle. Cruse: If we time our cars to run on US fuel with the stock system we are going to be at about -25 or -26 at curse. Our low compression motors when under the low demand of cruse I suspect can benefit from being at about -36 and read of one built turbo running at -42 on the freeway. This should help efficiency /fuel economy significantly as much or more that 5%. Fortunately, running less than ideal advance at cruse dose not effect the ability to make power. Boost-Retard: The stock system goes to full retard at about 5 PSI. Thus, it is kind of an all or nothing. This might be less than ideal. If so pulling back boost in a more progressive manner might add some power to the spool part of our operating range. Spool being that point between boost onset and full boost. Further, with the stock 930, Boost-Retard is a fixed position. If one runs .8 bar and wants to jack boost to 1 bar from time to time, one would have to compromise on the side of safety and run less advance at the lower boost level. With a programmable system we can better fit the boost timing to the actual boost level. Additionally, as a motor is more sensitive to detonation near Torque-Peak, a programmable system should allow us to bend the advance curve around TQ peak and thus make more HP later in the rpm range with more ideal advance. With this system I believe we lock out the existing mechanical advance and set timing to about -16 and eliminate the retard-can. We then use the stock trigger signal and plumb in GM MAP to the intake manifold for load. Thus, combining fully programmable MSD with CIS could be a powerful combination and improvement. |
Modifying the stock system:
Because of the design of the stock system it is not a good idea to just set the timing for more static advance. This is because the on boost timing will move with it. Thus, on cruse advance is going to mostly have to be lived with at the expense of MPG. Again, this dose not have any solid impact on performance. On Boost: Setting the stock US dist at -26 deg yealds about -16 to -18 deg of advance on boost. I suspect we really need to be near the lower end of this for safety. Bruce Anderson in his book on modifying Porsches suggests setting timing at -25 if running .9 bar boost on a modified 930. We do not want to advance this any furter. Off idle: It looks like -15 with very quick advancement offers better throttle response. To get this the best way will probably be to shorten the mechanical advance feature. Further, we see full advance by -3000. Some readings seemed to indicate that we might benefit from seeing full advance by 2500rpm. How do we modify for this. One is to “re-curve” the distributor by putting softer springs in it so the weights advanced faster. The other is to shorten the mechanical advance. This can be done by limiting how far the weights are allowed to extend. How much we limit this is open for debate. I am leaning toward killing the Vac-Ret function totally. This would advance the timing to about -8. If my goal is -15 at idle that means we need to take about 7 deg out of the mechanical advance. 7 deg of 18 is about 40% of total advance. Thus, we would need to reduce the weights ability to advance about 40%. This will effect when we get total advance and it might make total come about 25% faster so this might be all we have to do. If however one wants to keep the Vac-Retard function to maintain the increase in rpm that is available during the cold start function (and maybe A/C tuning on but not sure), we might target something like -10 at idle with every thing hooked up. That would mean taking about reducing mechanical advance about 11 of the total 18 available. This is about a 55% reduction in weight travel. This, we should be able to increase our off throttle response by shortening the mechanical advance part of the total advance available to us. Note: I suspect the small solenoid that is hooked up to the low pressure side of the distributor (Vac-Ret) has an important function in achieving boost-retard. If this solenoid id not function, boost will enter both sides of diaphragm on the distributor and in effect equalizing pressure on both aides keeping it from retarding. One resource indicated that with his test, applying boost to both sides of the retard-can still retarded boost, however I would not want to count on that. |
MSD with Boost-Retard in series w stock.
This is being done by a couple here. With this timing can be advanced from -25 to about -36 using the factory timing method. Thus, gaining fuel economy at cruse. It also advances timing off idle from +1 to about -9 for improvement off idle. The boost-retard available from MSD then is used to pull timing back the 11 deg that static timing was advanced. The added benefit being the higher output at low rpms where we can use it. Further, it was pointed out to me that another advantage to this set up it is easier to back things out of one has issue meeting smog cert’s if needed by disabling the MSD retard and retiming the car. (Thank you Chris Toy “930-356” for suffering through my questions and helping be better understand a 930’s ignition.) |
MSD w Boost-Retard substituted.
This might have some potential and involves disabling the Vac/Boost-retard canister on the distributor. It can gain many of the advantages we seek plus having timing on boost come in, in a more progressive manner. (I suspect if I was building a 930 today this might be what I actually do a version of this but play with the mechanical advance. ) There is a limitation with this unit in that it can only retard timing a max of 15 deg. Thus, if we want total timing on boost to be at -16 we can set total timing at 4000rpm at -31. This is better than -26 but short of cruse ideal so we should see some improvement. If total timing is at -31, 18 deg of that would be from mechanical-advance. Thus, timing at idle would then be -13 which should be a solid improvement but probably less than the motor would take. This approach might benefit from a softer spring in the distributor that would bring in total advance in faster. Optionally one might hook up the Vac-Ret hose (closest to the motor) if desired for a bump in rpm during cold start and bring idle timing to about -5 deg. |
Disclaimer:
I am not an expert, just someone that loves figure out how Porsche’s work. First is was MFI where I eliminated the thermostat, adding an external AFR adjustment knob to the injection pump, remote cold start priming, and grinding on my own space cam for my 2.8 twin plug build. Next it was CIS when about 7 years ago I set up my own WUR add on that was programmable for all loads and rpm levels so I achieved near ideal AFR’s everywhere, more fuel up top, and increased throttle response. Way before the D-WUR popped up. My thoughts also resulted in the first higher flow fuel head that went to Brent 930 that then became the HF head. I also first suggested the use of the RPM boost circuit clamp using an MSD switch that was just one way to try to tame the increased fuel that came with the modified fuel head and a desire to access increase fuel needed up top by lowering control pressure (a reverse Andial-Fueler approach). I make a lot of mistakes along the way to learning and might have made some here. However I hope other’s will offer positive correction where needed and new ideas so we can all benefit. :) |
Great start on what may prove to be another great thread!
I know of three of us (myself, Chris, and Cole) that I believe are still using the MSD boost retard module to gain controlable advance and to shave it off progressively as boost builds. I think Chris is running with the most static advance (and until I re-index my distributor, I'm stuck at 8 degrees max). Besides the improved lower end power and response, I'm getting very close to 20 mpg when just sanely crusing down the highway. |
I like what you guys have done. Better timing and a better quality spark with the MSD. You probably have not left much on the table to be improved.
I do not want to slight the stock components as if AFR's are well managed the stock components are very solid. |
great thread, and just in time for me to work on the timing table for my EFI/ignition control project. It has been explained to me like this: An engine at WOT is at it's highest efficiency, any throttle less than 100% is less efficient and therefore needs more timing advance to compensate. In my experience with user programable efi i always targeted 25-30 advance at idle then moved to 35-38* as the engine approached 2500rpm and keep it there till the onset of boost. So i tend to agree with everything you've mentioned so far, except i will not be keeping the dizzy. crank trigger/coil pack and full user control is the way i'm going. I'll be able to dictate how much timing the engine will see in every rpm/load scenerio possible.... my biggest issue right now is WHAT those numbers should be.... i'm all ears
Individual cylinder knock retard is also quite useful:)
Well here goes a "for what it's worth"
First, thanks to Keith we are looking at a topic that is rarely discussed and very misunderstood by most of us. I have been looking at timing for some time now as I think it happens to be a largely overlooked performance enhancement that is nearly free compared to some of the mods we do. As we start here remember that the word death is actually spelled "detonation" and you need to know how to avoid it because it will destroy an engine in a millisecond. So before you even think about screwing with timing make sure you have considered the following preventative measures. Never run pump gas go find the highest fuel you can get and use it religiously, install a larger intercooler, definetly have a system to monitor AFR's and know what your afr's are always, make sure you have a good free-flow exhaust or header system, consider running one range cooler plugs, and don't screw with the timing without knowing what your doing. I am aiming this at all us poor bastards that can't afford to destroy a motor and go buy another tomorrow and run the standard bolt on type mods. Our cars call for around 0 - 4 degrees at idle and 26 - 29 degrees at 4000 rpm. A couple little tid bits: you can actually experience detonation in the 800 -2500 rpm range if you advance initial timing too far. At higher RPM's we don't need excessive timing because our engines are relatively low compression and excessive timing increases the chance of detonation, cools exhaust temps, and creates power loss. Excessive retarded timing at higher RPM's will create excessive heat in the heads and cylinders and loss of power. From what I have gleaned from a lot of reading is it's good to add about 6 - 12 degrees of initial timing as this will improve low end performance, but once you reach about 2 psi of boost you need to start retarding timing and end up at the 24-26 degree at 4000 rpm. There are several ways to do this. I have a MSD6AL and a MSD Boost Retard in the "Old Sled" which makes it pretty easy. There are also ways to replumb the distributor pot to retard timing when intake pressure becomes positive at boost. Also the distributor can be recurved by changing springs and weights. Hopfully someone smarter than me will tell me I'm full of s--- and we can get this thread moving. Untill then this is my story and I'm sticking to it. Cole |
subscribed...
Yes, an A/F ratio gauge is good, but it can't detect knock or do anything about it. Running rich doesn't guarantee you are safe.
If you are worried about detonation, get a system that can respond to inaudible knock and keep it inaudible. Here is a link to a short clip that shows an individual cylinder knock controller on an engine tuned for 91 octane, but running a 50/50 mix of 89 and 91. The system is responding to inaudible knock: bgstew6's knock controller demo Your engines are rare and expensive. The knock controller is a small price to pay to protect it, and it won't slow you down, since it retards only the knocking cylinders. |
subscribed... It is just what I need to know...
Cole,
Thx! I am sure I still have alot to learn and am glad to get your imput. Everyone wants to run 12/1 AFR w big boost and they are not looking at the ignition side. I am concerned that many of us are running to much advance on boost and do not even know it. I suspect that the original stock setting at -26 US at 4000rpm may not be enough for a built car. Again, Bruce Anderson notes setting it to -25 for a car that runs .9 bar or has limmited runs to 1 bar. That was written years ago and I think before we started getting the gas with alchol in it. Also, one ignition sheet I was given showed that timming on boost was pulled back with more boost retared of about 1.7 through 1 deg more when going from .8 to 1 bar boost. Thus, we might want to look at setting timming at about -24 for a car with a health unmodifed igntion if running more boost. We need to build safety in to the tuning of a 930. It dose not have the ability to adjust timming and fueling with temp or altitude like the more modern cars. Timming on boost is directy tied to full timming is set at on these cars and is retarded about 8-10 deg from that setting. Anyone that sets there timming at -29 probably better be running race fuel because they could be at -20 on boost and need to be as low as -15 or so. Yes, run the best fuel possable but set up your car to work with what ever you usally run. Detonation is not directly tied to timming. Pre-ignition is. Detonation is when there is ignition from heat or compression before the spark. Anyway. When I was big on understanding CIS I concluded that one of the reasions for the high rate of failures with 930's was because of the potental for uneven fuel flow per cylinder (others say uneven air flows). As such I am a big beliver is having the injectors cleaned and matched and the head ballanced so we are not in a suituation where we think we have a healthy AFR of say 11.3/1 on boost but have one cylinder at 14/1 with the others at 11/1. Now that I am looking at the 930 ignition side it looks to be succeptable to failure. If the vac hoses are not in good shape or the diphram in the retard-can is leaking we will not get retard and will be pulling -25 deg when we should be at about -15. This system dose not fail toward retard. If fails and we get no retard but do not know that is what happened. Also, there is a little solonid on the vac-ret side of the can the seems to be essential to getting boost retard. That solonoid really needs to close on boost. If it dose not, both sides of the can recive a boost signile that should cancel each other out. I suspect if that happens, we will not get our boost retard. One member I talked with thinks the dist has some magic in it that if the dist dose get an equal boost signle to both sides of the retard-can it will still retard against its spring. It would be good to have someone put a hand pump tee'd to both sides and add pressure to see if this is true. I am very suspect. If I were doing a 930 I would 'look at' removing the Vacuum-Retard side at the can so I would not have to wate for the vac to go away to get my advance and to protect me a little bit more from failure. Thus, we are probably running to much timming to begn with for a motor that is running higher boost, we probably have less than ballanced AFR's at each cylinder, and have a higher than average suseptibility to ignition failure that would limit our boost-retard without us knowing it. |
subscribed!!
MSD!
Mark, Chris or anyone that has done an MSD conversion, can you confirm what needs to be done? Tach drive? Rotor, eliminate resistor? Rev-limiter, do we need a "pill" at the MSD box to reestablish the rev limit? MSD in concept is a great fit with a 930's lower compression ratio pre-boost than almost any other turbo cars and with it's CIS that tends to have a lean surge off idle. These two factors make for potentally a difficult mix to fire. Outside of twin-plugging it seems a very good way to address this. Even if it is not used for any other purpose. |
Keith,
I have an 80 ROW 930 and therefore have a single pot distributor and the factory timing spec is 29 degrees at 4000 RPM. Total distributor retard is 4 degrees. I used to re curve distributors on small block Chevy by changing springs and weights. Jerry Woods at Smart Racing will still rebuild and re curve a distributor if you send it to them. So there are still resources out there. I personally think twin plug and programmable digital timing control is the right choice if you are running a serious track car, just like EFI is the way to go for fuel. But none of this is practical for the average smuck like me running on the street. Hell that 16 grand it takes to twin plug and EFI would actually pay for 1 of the 18 chemo treatments I'm still paying for, so The Old One goes to Evil Bay and buys MSD parts. I have a MSD 6AL 6420 $64.00 and shipping used, a MSD Boost Timing Master 8762 $34.00 and shipping used, a MSD 8920 Tach Adapter $40.00 and shipping new, MSD 8207 Blaster coil $28.00 and shipping, Porsche non resistor rotor from our host $15.00 and a new set of Magnecor 6594 Plug wires on line for $140.00 and shipping. I have a total of $321.00 in parts and sold my Bosch CDI and Coil on the board for $350.00. Probably not the best system available but it really works great for a street car and I am very pleased with it. I made up a harness that allows me to plug directly into the original engine harness connector. Pretty sweet set -up. I run the MSD with a 6000 RPM pill. Cole |
I am following this with interest. I have a electromotive xdi and twin plugged engine but my timing is at factory settings because I have no idea on witch way to go for timing issues to get more performance. This system uses a map sensor to retard timing under boost. It is set at -26 total . I also have all the usual upgrades k27,adj wur,fuel head, enrichment rpm switch,etc, The car just not perform the way I would think that it would and have always suspected that playing with the timing would help performance. The problem around here is who can help ? most of the shops in my area only know about the stock set up and the ones with a dyno I wouldnt trust with a pedel car. So if you guys think that my set up will be comparable with the stock set up in timing adjustments Im gonna give your settings a try . Timing just reads like german to me so I am gonna try to learn from your experiments. Thanks....Ben:eek:
[QUOTE=911st;4915859]MSD!
Mark, Chris or anyone that has done an MSD conversion, can you confirm what needs to be done? Tach drive? Rotor, eliminate resistor? Rev-limiter, do we need a "pill" at the MSD box to reestablish the rev limit?QUOTE] The "Old Man" on the block spelled it out pretty well. If you already have an MSD6AL ignition, then it's a simple matter of adding the Boost Timing Master 8762. If you don't have the 6AL, MSD also makes a complete unit which combines the 6AL features with the boost timing master in one nice package. The two work in conjuction with each other and I think I only had to connect ground, power, disconnect one wire from the 6AL and connect it to the 8762 and off we go (oh...don't forget to attach the vacuum line to where your normal boost signal is taken). Very simple installation. You then dial in how many degrees of timing you want to retard for each psi of boost...which you also dial in. The key is to drop all the extra timing by the time you're seeing any significant boost. Still running with the 6000 rev limiter chip in my MSD6AL. Once installed and you've set your static advance to where you think you want it, you then take your handy-dandy Mity Vac or suitable source of compressed air to check that the timing retards as you add boost pressure. Do this at idle to see that it all goes away, and do this at 4000 rpm to see that you still end up with 26 BTDC (or whatever your engine specs calls for). |
Cole,
Thx! Very resourceful. Yes, Jerry Woods is a great thought. Years ago Brent 930 sent his dist to them. I recall them wanting the throttle body to so they probably changed the vac to a full on connection instead of a modified ported one. I believe they abandon the Vac-Retard side which I assume makes is more like a Euro Dist. The also recurved it which I assumee was for faster advance. Someone should get with them and find out what there program truly is if they will disclose what they do. I have to ask, are you sure about there only being 4 deg of on boost timing retard and they you end up at -24 on boost? From what I have learned a 930 has about 9 deg of retard and should be at about -16 at full boost. I know that is for a US dist but I would not expect much difference except for the total advance. I have to say, until I looked into it, I thought that they were at -25 on boost to. I believe my 3.2 Carrera is only about -25 at WOT, it is a higher compression, and dose not see any boost. From 911Chips.com web site: http://forums.pelicanparts.com/uploa...1253826828.gif Note full advance by 2500rpm. The best. |
Hey Mr. Mark great to hear from you, glad you've stepped in here.
What are you using for initial advance at idle, when are you starting retard, how much timing do you take out per psi, what do you have at redline, and has initial advance enhanced your low end performance. I thought I might post a couple pics of "The Old Sled" as I'm in the process of cleaning up the wiring for the MSD, LM1, MAP & Pressure sensors, AFR Display, EBC, and related switches. http://forums.pelicanparts.com/uploa...1253828336.jpg http://forums.pelicanparts.com/uploa...1253828420.jpg http://forums.pelicanparts.com/uploa...1253828449.jpg http://forums.pelicanparts.com/uploa...1253828480.jpg http://forums.pelicanparts.com/uploa...1253828538.jpg Cole |
I love pictures!
You know, sometimes I feel like I'm playing with a very expensive fire, but I'm the kind of old guy that learns by doing. Take the best information I can get my hands on, use my own at times twisted logic, and go for it. At idle I'm at 8 BTDC...as much as I could get twisting the distributor to it's stops. I'm gonna have to look at the dials again, but I think I set it to begin retarding at 1 psi boost and adding 1.5 degrees of retard for each 1 psi. So basically by 5 psi (about .34 bar) all those 8 degrees of advance have been taken out. Some may say that I should have all the advance gone by .2 bar, so maybe I'm living on the edge here. Would love to hear any comments in that regard. At redline, I simply don't know (I rarely touch 6000). But at 4000 and no boost - tuning in the shop - timing is at about 34 BTDC (the 8 degrees I added at static plus the normal 26 from mechanical distributor advance). When on boost, 8 degrees of that comes off due to the MSD thingy, and probably another 8 degrees comes off due to the vacuum distributor boost retard, leaving about 18 degrees advance at full boost. My goal was to add static timing and take it all back off at boost, resulting in the same advance @4000 rpms as the book calls for. I would like to try more static (as in up to 12 degrees) but the damn dizzy won't let me...yet! Performance improvements? I wouldn't say it knocks your socks off, but I will say it gives more grunt and quicker revs from 2000 to 4000 rpms...which is where I wanted it. As a result boost seems to build just a little quicker, which is good for my 7006 turbo. Mark |
a. P/N 6462, aka MSD-6BTM, has an integral boost retard controller, providing for a boost controlled retard rate from 1 to 3 deg/psi, maximum 15 deg. Retard onset pressure is fixed (starting at 0 to 1-PSI?). b. P/N 6420 with P/N 9762, aka MSD 6AL with Boost Control Module. Improves on a. by giving control of boost retard onset pressure from 0 to 5psi. c. P/N 6420 with P/N 8977, aka MSD 6AL with Multi Function Ignition Controller with Boost Control. Improves on a. and b. by providing control of ignition timing by rpm and boost retard onset and rate (up to 25 degrees retard). Boost retard is "additive" to any timing map. In other words, lets one build a detail/custom timing map. This digitally controllable system can be used to eliminate the distributor’s vacuum/boost advance/retard and mechanical advance. Not an engine management system (EMS) but rather a total ignition timing management system (TITMS). The system uses PC based Pro-Data+ software (free) or for the non-computer racers, there is a hand-held Programmer Monitor ($229). Factory costs: a. $415 b. $513 c. $729 Re Rotor - These systems generate/put out a major amount of energy. If the stock ignition rotor has a resistor (buried in the black epoxy bed, center top of rotor), it should be dug out, a 12AWG solid copper wire soldered in its place and re-epoxied. (There are those who have never eliminated the resistor and had no problem and there are those whose ignition failed on the road, on the track when the resistor became toast. Resistor roulette doesn’t seem a smart game to play.) Re Tach Drive: MSD has a 12 volt square wave signal with a 20% duty cycle. If the stock 930 tachometer cannot accept this signal, add/use MSD P/N tach adaptor ($65). Re Rev Limiter: MSD-6AL series uses a rev limiter "module," a small 2-pin device that plugs into the bottom of the ignition, set for a specific RPM. Available in 100-rpm increments i.e. 6500, 6700, 6800 etc. NOTE: If the module is removed, falls out, No rev limit. Mounting the MSD-6AL upside down makes sense. Unknown how Multi Function Controller (P/N 8799) handles rev limit, most probably via software. Of the three systems, I vote "c." for a CIS-930. |
Excellent Chris!
And big, big thanks for helping me learn to try to learn about a 930's ignition. The best. |
Great thread. I would just like to point out few things:
Goran,
Good catch. You are correct, I was thinking of the SC pistons. On the turbo they needed a flat piston for low compression so a piston that would create swirl in support of better mixing was not an option. As we know, CIS sprays fuel for two compete turns of the crank (720 deg's) for each one time the intake valve is opened (apx 220 deg). That fuel just sits near the top of the intake valve waiting for air to come by and mix with it. Increasing volocity at the intake port help this and better lifts any wet fuel sitting on the sides of the intake port. It takes more than an increase in volocity at the intake port to benifit low rpm power. It needs to be combined with just the right intake runner length and volunm to create the pressure waves needed to push more air into the cylinders at the targeted rpm. Thus, my personal belife is this velocity has little to do with filling the cylinder for stronger low rpm operation and was a trade off to support a weakness that comes with CIS to better meet emissions. I know this is not what most have concluded. I also wonder if we were not running 2.0 911T sized intake ports, if we might actually increase low rpm filling but as a lower volicity. In any case larger ports should reduce restriction during "spool" time (boost onset to full boost). Interesting about the shaved cylinders. Bruce Anderson says the same thing in his book about the cylinders being shaved. Could there also be other reasoning? It is interesting that with the later 3.3 & 3.6 C2 Turbo's did not do that, nor the 993TT. Nor was any of the upgrade P&C kits like the 3.4, RUF short skirt 3.4, or 3.5 kits. I guess as this happened at about the same time Porsche went to a 5 blade fan on the 1977 911's in and effort gain more heat for the thermal reactor exhaust (not increase HP with less drag), it seems easy to think it might possibly be emissions concerns were at least part of the reasion. The 3.0 turbos has both full fins and larger intake ports. I am not saying I am right, just what I belive. Thanks for the input. |
I have a set of 1976 3.0 turbo heads for a 95mm bore sitting in a box waiting to have the edge of the combustion chamber beveled one full mm into the squish band all the way round so I can use them on a 3.3 with 97mm bore.
I'm mentioning that because I've measured with calipers and the intake ports are 32mm just like a later 3.3 head. It's the exhaust ports that are 2mm wider in diameter and that seems to be in the middle part of the exhaust port area a little after the valve guide and before the before the exhaust port flange. The port diameter right at the flange is the same as a 3.3 so the exhaust headers match up the same. The port sizes for different years of all the air cooled 911's are in the specs in the back of Waynes book. I've heard the reason for the half finned 930 cylinders was to try and keep the clamping force of the 4 headstuds closer to equal. The exhaust valve side of the head runs alot hotter than the intake side and do to heat transfer the cylinder and the headstuds do too. This causes the headstuds on the bottom or exhaust side to expand more and the clamping force weakens on the bottom side leading to the bottom side of the cylinder heads lifting under high boost. So, Porsche removed the cooling fins on the top side or intake side of the cylinders to try and equalize the heat in the cylinder and maintain closer to equal expansion rates of the cylinders and headstuds for better sealing and less chance of warping or leaking. and, I don't know for sure if that is correct or not. |
Thanks jFairman.
We have learned a lot about head studs sense then and the concept is interesting. I think on at least one of the 911's Porsche put different studs (delivar?) on the bottom and steel on the top which supports the thought. Could be a combination of reasons. Me, if I were to build a 930 motor I would want full fins. I wonder if the heat from the thermal reactors was the source of the extra heat that the bottom of the motor had to deal with. If so, they could have sacrificed cooling on the top of the cylinders to get them hoter. Cured a different problem than we were thinking of. Still an emissions issue but not done because they wanted the motor to run hotter, it was just that the exhaust ran to hot. Makes at least a little sense. Just a guess. Fun! |
The SafeGuard is a great alternative to the MSD boost retard system.
It has an option for a second coil driver, so one system can drive two coils. The ignition is inductive, with constant energy dwell control, similar to Bosch Motronic ignition. The unit can trigger the Bosch CDI unit if you prefer to retain it. No other system does this, as the Bosch CDI requires an ac trigger signal. There are two adjustable rev limits (staging and top end), which can be set with just the key on and a voltmeter. Measure the test point and turn the adjustment knob to get the desired rev limit. For example, 6.25v equals 6250 RPM. There are four retard modes, including cranking retard, nitrous retard, boost retard, and individual cylinder knock retard. The boost retard includes a start knob, allowing you to enable boost retard as late as 10 psi. Test points allow you to pre-set the Start and Rate knobs. Individual cylinder knock retard protects the engine while allowing the highest efficiency. The final frame of the video I linked to above shows cylinder #5 is retarded eight degrees. No other cylinders are retarded. Cylinder #5 is known to run hot on those engines. One tuner that I know uses a heat range three numbers colder than used in the other cylinders. Remember, when you set timing for "no knock" you are setting it for the worst cylinder, the one that pings the easiest, robbing power from the other cylinders. http://forums.pelicanparts.com/uploa...1253911394.jpg |
John,
Appreciate your participation but I'm not hearing much from you about timing curves. I feel like your selling me something. If that's the case please give me a web site and then give me your input on the timing curves for 930's. Thanks !!! Cole |
We do need to know some bench marks.
What dose a turbo motor with 7/1 compression running .8 or 1 bar should expect to be: At idle, On boost, On the freeway John makes a good point about variations in heat between cylinders. We also have various with air flow and fuel delivery with each cylinder. There is also increased sensitivity at different RPM depending on the cam, and actual AFR we all know varies a lot on a modified CIS 930 accross the RPM range. Add to that the fact that these cars have little to no compensating features and that is a lot of exposure. So when someone says they make more power at 12.2/1 AFR or at -27 deg advance they are running closer to the line. If in good balanced tune they may be ok. If not... |
Don't the euro cars run 29 degrees full advance? Only heard of vacuum retard at idle on those motors, single pot dizzy, no boost retard. What's up with that?
Good catch, yes I would like to see more of these used on this platform.
This unit is designed to work with an existing timing curve, whether it's generated by a mechanical distributor, or a fully mapped curve generated by an ECU. As is the MSD-6. Engines with a fully mapped curve can also benefit, as shown in this series of dyno runs taken from a 2.0L Eclipse engine used in a Formula III car. It's naturally aspirated, but the compression ratio is 14.0:1. The timing curve was mapped on the dyno with a MoTeC using headphones with a knock amplifier. Timing was set to provide a two degree safety margin from knock as indicated by the headphones. The SafeGuard was then installed, and the timing was progressively bumped in two degree increments. No other changes were made, except for the last run, where spec fuel was used. The engine was run for the '04 season with the SafeGuard with no damage from detonation. The data is from Ian Whiteside, a calibration engineer at Mercedes/Ilmor in the UK. To be clear, it's from his personal F3 car, and the runs were not done at his place of work. http://jandssafeguard.com/Ian/Ian'sData.gif |
I have been wondering about that and we need to verfy if that is the case. However, that would not add up from what I understand so far. From my reading Vac-Advance is to premote fuel economy when not under load and Vac-Ret is to permote heat for emmissions. Thus, I can see why we have Vac-Ret added to a smog 930. However, with a turbo we have to have "boost-retard" for safe running under boost. As the Euro and 3.0T's only have one conection to the can on the dist we can not have both vac-ret & boost-ret. Thus, somthing is not adding up unless there is two different euro cans. One with two conections and one with a single conection. Further, the euro has a broder timming range by 2 deg (see below). Is that extra range in the mechincal advance or in the Vac-Retard (if it has such)? I do not know. I would guess a euro turbo that have a can with one vac/boost line conection would just have boost-retard. As such, timming at idle (conected) sould start at somthing like -11. It would have mechanical advance to take it up to -29. Under boost timing would be pulled back to about -19 (to run w the better euro fuel). Dose anyone have the timing igntion specs for a 75-77 3.0 turbo? Or, is there an early euro timming spec? From another post, the specs for US and Euro: -------------------------------------------------------------------------------------- USA 1 +/- 2degs at idle (950rpm +/-) Vacuum Hose CONNECTED Euro 2 +/- 2degs at idle (950rpm +/-) Vacuum Hose CONNECTED And to adjust timing: USA 26 +/- 1deg BTDC at 4000rpm Vacuum Hose DISCONNECTED EURO 29 +/- 1deg BTDC at 4000rpm Vacuum Hose DISCONNECTED -------------------------------------------------------------------------------------- |
The early single pot Euro distributors do not have boost retard. I have stated this in many threads and it seems to be a cause for confusion. The single pot is vacuum advance. Once you get on boost you no longer produce vacuum so advance stops. I set them at 26* and lock it down.
at first glance 26* of advance sounds very aggresive for an engine running 12-14psi of boost and designed to run on 93 octane. But since this engine has only 7:1 compression I can see how it would tolerate that much advance. Now the car comes over to the states with all it's power robbing emissions crap, and Porsche knowing damn well some moron is going to pump in some cheap 87 octane fuel and beat the heck out of the car in Arizona in August, it's easy to see why they would add the second vacuum/pressure reference to the dizzy which pulls some timing under boost. My mechanic told me to yank the vacuum hoses off and lock the dizzy at 25* the day i bought the car because he knew i would only run good fuel.
| All times are GMT -8. The time now is 05:01 PM. |
