-   -   strange electrical problem (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/509867-strange-electrical-problem.html)
speednut 11-09-2009 11:41 AM
Hopefully someone has heard of this.My reverse lights don't work,fuses good,bulbs good,I can put 12v to the grey/brown wire at the switch and the lights come on.I think my problem is the supply?Lastly when I put it in reverse the druck pressure goes to "0".....Thanks for listening. 87 930 in case I forgot to mention..
proffighter 11-09-2009 01:06 PM
What about the switch at transmission itself? Easy to check using Ohmmeter
mark houghton 11-09-2009 01:29 PM
What pressure??? Is that like Quantum Physics lingo?
My guess is you have a bad switch.
speednut 11-09-2009 01:31 PM
ohmed the switch , its working properly,its new.
JJ 911SC 11-09-2009 02:51 PM
I've seen this before...
Speednut
I've seen a thread on this before (pressure going to 0 when reversing)...
Unfortunately memory (and bladder) is like a sieve and could not find it if my life depend it on it.
Should get a solution before the Sun rise in the East.
J.J.
HFR_Racer 11-09-2009 03:19 PM
speednut..
Sounds like you need an electrical diagram. If you ask nicely in this forum someone should be able to help you out with a print. The oil pressure sending unit works on resistance and is not in the same circuit as your back-up lamps.
speednut 11-09-2009 04:24 PM
I have a diagram,this is the strangest thing I've seen..I have never had an electrical problem that I have not been able to fix ,but makes no sense...........It's all most like someone has messed with it ! Some how connected wires wrong..
Helmsy 11-09-2009 05:49 PM
Trust me this is very possible. ;)
JJ 911SC 11-10-2009 12:52 AM
Before the Sun rise...
Originally Posted by JJ 911SC (Post 5001408)
Speednut
J.J.
Found it...
May not be your problem but there is something in common between the Oil Pressure gauge and the back-up light.
Check entry # 6 & 8 of http://forums.pelicanparts.com/porsche-911-technical-forum/497418-oil-pressure-gauge-pegged.html (ignore the title)
speednut 11-10-2009 05:02 AM
Thanks JJ911SC!! I think someone messed with it..Thursday I'll check that,betcha any thing the wires got switched..
JJ 911SC 11-10-2009 05:03 AM
Keep us posted...
A930Rocket 11-10-2009 05:33 AM
Did you or someone work on your car recently? Or did I miss that in your post?
speednut 11-10-2009 07:44 AM
I just bought it wensday 11/4/09, the problems I'm sorting are the p.o.'s
clohman 11-11-2009 06:45 AM
I had a mouse take-up residence in my trunk who ate through the protective sheath of a 1.5" wire bundle. WIth your meter dropping to zero concurrent with the reverse circuit being activated, a wire diagram would help you look for areas where the two circuits are adjacent to each other. Might want to also begin looking around for evidence of vermin "residents", i.e. droppings, chewed-up carpet to make a bed, etc.
Hope you find the problem.
Chip, Woodbridge, VA
speednut 11-12-2009 03:45 PM
Thanks all , JJ sc911 , special thanks,the thread you sent me was what I needed.Someone switched the wires ,that caused the whole problem!Nothing worse than trying to trouble shoot something thing that someone else FORKED UP! MANY THANKS!!!!!!!!!!!!!!!!
JJ 911SC 11-12-2009 04:08 PM
Great
One down, many more to solve...
A La Prochaine
J.J.
cfashioniqpx3 11-14-2009 06:18 AM
Ms. Jewelry (4)
[color=#1f3730][font=Times New Roman][size=3]cdcd[color=#1f3730][font=Times New Roman][size=3]erre[color=#1f3730][font=Times New Roman][size=3]ddee[color=#1f3730][font=Times New Roman][size=3]sssa[color=#1f3730][font=Times New Roman][size=3]kakak
