AFD660's Avatar
A/F gauge
hey guys i just recently purchased a 930 from a board member... car is awesome.. i'll post another thread later about it.. lol..
i have just one question or concern about its A/F ratio gauge. whenever i flip the ignition on or off.. only the last 4 yellow lights in the stoich and all of the green light up... when driving its the same way.. only the last 4 of the yellow light up.. and the green does to..... and i noticed sometimes the gauge doesnt register anything at all.. then driving down the road a little ways it'll start working again... i traced the wires and they are all good.. wires seem to have a good connection... should i be concerned about the other lights not coming on?? could it be the gauge is faulty or something else... thanks... oh the gauge is an autometer pro comp ultralite.. thanks again..
Old 12-11-2009, 05:20 PM
Turbofrog
smurfbus's Avatar
My two cents:
I would not trust a narrow band sensor/gauge even if it worked ok. If you need to tinker with it you might as well check out the wideband options. IMO the Innovate is the only system sofar that is accurate through the life span of the WBsensor (auto heater calibration + manual sensor calibration). Search for lc-1 for more info if you just want an accurate gauge without logging.
Narrow bands do operate OK'ish on stoich close to 14.7AF
Old 12-12-2009, 12:44 AM
A930Rocket's Avatar
^ + 1. You really need a wideband AF system and 14.7 is only good at cruising speed.
Old 12-12-2009, 06:45 AM
930gt-40r's Avatar
Turbo cars should not be without wideband a/f gauges...
I would go for the AEM- its as accurate as the Innovate and a lot less. Of corse it doesnt have the data logging capabilities that the Innovate has, but it does display the same info.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 12-12-2009, 02:59 PM
The NGK digital unit is also nice and easy to read and also priced reasonable.
Old 12-12-2009, 06:31 PM
Turbofrog
smurfbus's Avatar
How do you hadle sensor aging with those other brands?
Old 12-13-2009, 02:09 AM
